Thread: 06 top end noise after crank sensor replacement
Results 1 to 13 of 13
  1. #1 Re: 06 top end noise after crank sensor replacement
    Post a video.
    It's pretty much impossible for the motor to jump time through just doing a sensor replacement, so I doubt you bent a valve.
  2. #2 Re: 06 top end noise after crank sensor replacement
    Aug 2016
    Ohio
    I'm fixing to record it, but as I was loosening the bolt for the crank pulley the pulley spun since I'm a poor bastard and don't have an impact. Is it possible that they can be bent from that? I don't know Pontiac, I'm a VW and Ford guy.
  1. 2004 GTP crank sensor
    By phil morris in forum 04+ Specifics
    Last Post: 06-22-2013, 05:26 PM
  2. 3 wire crank sensor vs 2 wire with 24x crank trigger
    By greenmachinegtp in forum PCM Tuning
    Last Post: 03-12-2012, 05:45 PM
  3. Crank sensor and DIC issues
    By lucyboop in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-12-2011, 06:28 AM
  4. camshaft sensor or crank sensor?
    By Viper in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-06-2010, 04:43 PM
  5. crank position sensor
    By vermsta in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-02-2008, 02:41 PM
