Thread: P0335 Crankshaft Position Sensor Problem
Results 1 to 9 of 9
  1. #1 P0335 Crankshaft Position Sensor Problem
    Jan 2013
    Kansas
    Hi, I have a 2008 Pontiac Grand with the 3.8, and about 2 weeks ago, I had trouble starting it. Like it would crank but die right away. Try it again and it would just kinda be clicking. Turn the key off and then try starting it again while giving it gas it would fire up. So I hooked my code reader up to it and the code was a "P0335 Crankshaft Position Sensor 'A' Circuit Malfunction." First thought of course was that the crank position sensor was bad. So I took it to napa had them replace it, when they replaced it, I took off and it did the same thing. I went back and asked them if they reprogrammed it, and they said that they didn't, when they had tried it just kicked them out.
    At first I thought they were just feeding me some bull, so I went to a buddy of mine who had a snap-on scan tool and the same thing happened. So what could be the deal? I took a look at it yesterday and no wires seem frayed, and I checked voltage on the pigtail and I had power down there, so what are my other options?
    On side note, idk if a battery would have anything to do with it, but I went on a four day vacation, this past weekend, and when I got back I tried to start my car, the battery was dead, quick boost helped that problem and its good ever since.
    Any help is appreciated, Thanks in advance!
  2. #2 Re: P0335 Crankshaft Position Sensor Problem
    the pcm might be bad. one of the repairs listed in the code.
    theres a fat square plug that plugs into the harness a top the lim by the coils. try opening and closing that plug a few times. mine was dirty and causing crank codes and others.
    that harness to the crank and cam is known to go bad. mine was also torn up.
    weak battery cant be helping things. id check the battery and the cars charging system. replace whats failing.
  3. #3 Re: P0335 Crankshaft Position Sensor Problem
    Jan 2013
    Kansas
    I would hope its not the pcm. Ill have to check out that plug in tho. Charging system, is around 13.5-14.5 usually while going down road, battery is fairly new too.
  4. #4 Re: P0335 Crankshaft Position Sensor Problem
    if it fails to do a crank learn id think is a pcm or a wire issue.
  5. #5 Re: P0335 Crankshaft Position Sensor Problem
    Jul 2010
    Coquitlam,BC,Canada
    Might be a long shot, but worth a look; I had P0336 a few years ago and it was some mouse-chewed CPS wires on top of the intake......
    http://chrisb.users.superford.org/Gr...336/P0336.html
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  6. #6 Re: P0335 Crankshaft Position Sensor Problem
    Jan 2013
    Kansas
    Quote Originally Posted by Bronco Boy View Post
    Winner winner chicken dinner, I don't know how I didn't think to check that in the first place, probably could have saved me $180 it cost to get it replaced since there was like 4 or 5 wires that had been chewed on and one wire completely chewed through. So thank you very much!
  7. #7 Re: P0335 Crankshaft Position Sensor Problem
    that just happened to another guy here. like he posted today about it. the mice are hungry all over the place i see lol
  8. #8 Re: P0335 Crankshaft Position Sensor Problem
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by 2coolit View Post
    Awesome. I did the same thing; assumed it was the CPS and changed it, then scratched my head when it didn't fix the problem.
    Mine was 3 years ago. Maybe it took my mouse that long to travel around and do its damage.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  9. #9 Re: P0335 Crankshaft Position Sensor Problem
    sadly, mice dont live that long lol
    a 3 rd guy just posted today, same thing, but it got 2 plug wires and the o2 harness lol
    my car was last registered in Newark NJ, place is a hole. under my hood all over was rat poison zip tied all over the place. now i know why lol
  1. crankshaft position sensor help
    By joshuasauce in forum Engine
    Last Post: 07-20-2021, 09:29 PM
  2. Replies: 3
    Last Post: 06-12-2014, 07:45 AM
  3. Crankshaft Position Sensor
    By pheasant plucker in forum General Tech Discussion
    Last Post: 12-29-2012, 02:18 PM
  4. crankshaft position sensor
    By brian a in forum General Grand Prix Discussion
    Last Post: 05-24-2012, 05:57 AM
  5. bad crankshaft position sensor?
    By ChdMcD in forum General Tech Discussion
    Last Post: 08-13-2010, 01:06 PM
