Thread: p0336 what to do
Results 1 to 2 of 2
  1. #1 p0336 what to do
    May 2016
    northern IL
    Hello, I posted a few months ago about crank sensor code symptoms. Well here's what is does, driving along ,engine stumbles tach dies , trac control light comes on, but will usually keep running, but sometimes will die and be hard to start, which is what happened today, but next time I restart it the tach works fine again, throwing codes p0336 and p0102 . Couple months ago I cleared the codes and the symptoms disappeared for a long time, just acted up today. I did a volt test on the crank sensor and got a voltage signal on both signal wires which says its working. From what I've read if the crank sensor is bad the engine cannot run at all, is it possible the sensor can intermittently be bad? wires look ok, guess I should examine wires and harnesses closer.
    Another thing I read was that a misfire caused by something else can cause these symptoms, such as bad plugs or wires .
    I'm going crazy.
  2. #2 Re: p0336 what to do
    time to get a new crank sensor installed. they work and fail as they see fit.
  1. 2000 grand prix p0742 p0336
    By i hate GPSE in forum General Tech Discussion
    Last Post: 04-11-2013, 02:32 PM
  2. Help with p0742 and p0336
    By i hate GPSE in forum General Grand Prix Discussion
    Last Post: 04-11-2013, 05:43 AM
  3. Code, p0336, tach quits and Traction control issue
    By jimtjr in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-31-2012, 12:04 PM
  4. Crankshaft Sensor Code Issues P0336
    By tboy160 in forum General Tech Discussion
    Last Post: 11-20-2012, 06:56 PM
  5. P0336 - Recurring Issue
    By Angus in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-18-2010, 09:31 PM
