Thread: Leaking Coolant
Results 1 to 4 of 4
  1. #1 Leaking Coolant
    May 2012
    Canada , Sarnia
    I have an 04 gp and Today at work I noticed a puddle of coolant under my car I drive an hour to work and I just had enough to make it home I know my lim gasket need to be replaced I just wanted to make sure its the lim gaskets causing major loss of coolant or be a rad hose
  2. #2 Re: Leaking Coolant
    May 2012
    Where winter never ends
    Check the coolant elbows under the alternator and near the lim. They are plastic and crack over time and cause this.
    2000 Regal - Winter Beater
  3. #3 Re: Leaking Coolant
    thats elbows, or the water pump. car off, grab the w/p pulley with 2 hands, push it on one side, pull the other then back and fourth, if you feel play the wp is bad. under it will be wet too.
  4. #4 Re: Leaking Coolant
    May 2012
    Canada , Sarnia
    I replaced the elbows last year with the aluminum ones that picture with the frame theres always a puddle underneath
  1. leaking coolant help
    By 02grandprixgtp in forum General Grand Prix Discussion
    Last Post: 12-20-2012, 04:38 PM
  2. Coolant Leaking...again!
    By jenmelo in forum General Grand Prix Discussion
    Last Post: 11-18-2012, 06:34 PM
  3. Think im leaking coolant
    By blackgpgt in forum General Tech Discussion
    Last Post: 02-14-2010, 03:56 PM
  4. Leaking coolant.
    By c002529 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-16-2010, 12:21 PM
  5. Leaking Coolant
    By seeth001 in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-23-2009, 06:03 PM
