One more update decided to check the pcv valve. In the process of getting to it while removing it I broke the MAP sensor in half, time for a new one obviously. But on the inside it is wet. Is this normal? I would think being a sensor it should be dry. Could this be the cause of my problems? And what is that fluid, and how did it get there? BTW I stopped when I saw this issue, never got to the pcv valve.
