Thread: Lifter Tick Questions
Page 1 of 3 123 LastLast
Results 1 to 20 of 48
  1. #1 Lifter Tick Questions
    GTP Level Member Kaiser Pontiac's Avatar
    Jun 2015
    Land of 10,000 Salted Roads and Rusty Cars.
    So, a few weeks back I changed the idler pulley on my L26 '04 GT2 and after doing that we heard what sounded like a lifter tick, so I took the valve covers off and discovered sludge inside of them and on the valve train.
    Per advice from here I got all the oil and coolant out, cleaned out the valve train quite well, put fresh oil and a filter in, got it all together and started it up. Still ticked, we thought we'd take it over to a mechanic friend and see what he thought, so we filled the coolant system up with water and back it up 20 feet and the ticking stopped... Drove it a few miles still no tick, shut it off, let it set for a few minutes, started it up, still no tick. So, we parked it and a couple days later I moved it and it ticked for the first 30 seconds or so, then stopped. Later I moved it to the shop and it did the same thing. Now, I've got the plenum and LIM off and besides my upper and lower LIM gaskets and VC gaskets and grommets - is there anything I should check, or take special care to clean while it's apart? I figured it just hydro-locked because of all the sludge, but why does it still do it then briefly?
    Thanks in advance for any help!
    06 LaCrosse 57-79k sold;99 4dr GTP 134-138k sold;98 2dr GTP 183k parted;98 Regal 166-184k;04 GT2 204-206k sold;04 GTP 170-175k sold;09.5 G8 GT Sport 145k;09 G8 78-84k+;08 Prix 164k sold;06 Prix 168k sold;02 Regal 92k;09 G8 103k parted;04 GTP SpEd 139k parted;04 GTP 205k;'09 G8 105k parted;06 Prix 230k;04 CompG 138k
  2. #2 Re: Lifter Tick Questions
    First off I'd clean the every living sh1t out of it. Remove rockers, pushrods, etc. Dump some oil all over the place in there, too.
    Replace lifters (you can get a cheap OEM set from Texas Speed for 3800 FBody's), clean pushrods and rockers...install new gaskets...button everything up...crank it over...check for leaks and such. Turn off...change oil and filter again. I always do this because any cleaning solution, junky oil, etc...you'll want to get out of there...especially if there is a coolant presence found...which it looks like there is on yours.
    If you haven't done it...I'd do valve cover gaskets, plugs/wires, T-Stat, PCV, vac lines (if dry rotted), clean the throttle body well...maintenance, really. If you're close to someone with a scanner or if you have one I'd have it hooked up to check fuel trims as well when you fire it back up to make sure there are no vac leaks.
  3. #3 Re: Lifter Tick Questions
    Buffalo
    X2. You're not that far away labor wise getting access to the lifters. Just remove rockers and rods and the lifter covers and replace em
  4. #4 Re: Lifter Tick Questions
    Jun 2015
    https://www.texas-speed.com/p-1619-g...t-lifters.aspx
    Those then? I got VC gaskets and grommets, T-Stat was acting up before anyways, vac lines look good... Thanks for the info!
    Our Snap-On Ethos should be able to watch fuel trims - I have no idea what to look for however, so I'll need some help on what's good/bad to see, lol.
    What's a good plug to run on N/A?
    Sent from my LG G4 using Tapatalk.
  5. #5 Re: Lifter Tick Questions
    some say you can reuse the rocker bolts, but they are TTY, so you should get new ones or re usable ones are about 25 bucks.
  6. #6 Re: Lifter Tick Questions
    Jun 2015
    Where's the best place to buy those?
  7. #7 Re: Lifter Tick Questions
    i got mine used so not really sure, iirc ive seen ppl say summit, and bite my tongue ZZP lol
  8. #8 Re: Lifter Tick Questions
    Jun 2015
    Ah, okay - just looking to find 'em cheapest, lol.
    These: http://m.summitracing.com/parts/cca-1053b-16 ?
    Also, for the PCV: http://www.amazon.com/gp/aw/d/B0049Z...pcv+grand+prix ?
  9. #9 Re: Lifter Tick Questions
    PCV valve...just go to your local auto parts store.
    As for rocker bolts...just get the Comp Cams rocker bolts from ZZP. Sadly...it's cheap...and you'll never have to buy them again.
    Also: double check the TQ on them (if I remember right...it's 25 ft/lbs...I also add a bead of Loctite...whether people say to or not...I've seen them personally loosen up under high RPM situations over time and develop misfires.)...that'll get you taken care of. If you really want to go overboard...get some L76 or LS6 springs too to help replace those worn out and tired ones.
  10. #10 Re: Lifter Tick Questions
    Jun 2015
    I'm not in town very much during the summer, free two day shipping from Amazon is easier for me, lol.
    http://zzperformance.com/3800/bolts/...ker-bolts.html So, what's better about getting them from ZZP vs Summit?
    Okay, yeah, I gotta gather the torque specs for all these bolts. I'd do better springs if I was keeping the car, but it's probably getting sold within the next couple months... Thanks for the information!
  11. #11 Re: Lifter Tick Questions
    If you wanna save some money I still have the lifters I pulled out of the 15k motor that I top swapped that I'm letting go (I reused my ls7 lifters from prev motor)
    Sent from my KYOCERA-C6745 using Tapatalk
    04 Comp G.
  12. #12 Re: Lifter Tick Questions
    Jun 2015
    How much would you want for them? (shipped to 56572)
  13. #13 Re: Lifter Tick Questions
    Jun 2015
    Both Summit and ZZP's rocker bolts and Comp Cams, but ZZP's says theirs is reusable, don't see that on Summit's... is that the difference? Summit's is cheaper, and probably ships faster than ZZP's.
  14. #14 Re: Lifter Tick Questions
    As long as they look the same, with the hex head...it's the same bolt.
    I ended up finding the same stamped bolt at my local hardware store for like .50 a pop. Loctite'd them and they worked just fine, too lol
  15. #15 Re: Lifter Tick Questions
    Jun 2015
    Okay, Summit looks like the better choice then.
    I thought bolts from the hardware store were a no-no because of unknown metal composition?
  16. #16 Re: Lifter Tick Questions
    Clear your inbox yoo
    04 Comp G.
  17. #17 Re: Lifter Tick Questions
    Jun 2015
    Sorry, lol, cleared!
  18. #18 Re: Lifter Tick Questions
    Sir ima need you to clear more then one message
    04 Comp G.
  19. #19 Re: Lifter Tick Questions
    Jun 2015
    Ya'know, I'd give money to have twice the message box space....
  20. #20 Re: Lifter Tick Questions
    Jun 2015
    Do I need to take that end plate off the LIM and clean inside?
    Also, how clean does this stuff need to be - I'm cleaning it with brake cleaner and paint solvent, an old paint brush and a rag, that good enough?
    And, after I run solvent through the engine and spray it down real good do I need to spray some oil on it before reassembly?
  1. Injector or lifter tick
    By Alexgp in forum Introductions/Noob Questions
    Last Post: 05-14-2016, 08:45 PM
  2. Lifter tick or something else?
    By 04gtpnoob in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-19-2016, 11:14 PM
  3. 3800 lifter tick
    By redynscire in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-27-2011, 08:00 PM
  4. Lifter tick?
    By My GTP 97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-22-2010, 01:03 PM
  5. Lifter Tick
    By 04CompG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-21-2008, 06:43 PM
