Thread: Lifter Tick Questions
Results 21 to 40 of 48
  1. #21 Re: Lifter Tick Questions
    leave the side cover on the lim, no need for it to come off.
    flush the lifter valley with new oil let it drain out the oil pan plug. waste a couple qts of oil.
  2. #22 Re: Lifter Tick Questions
    GTP Level Member Kaiser Pontiac's Avatar
    Jun 2015
    Land of 10,000 Salted Roads and Rusty Cars.
    Okay! What needs to be RTV'd? Some black stuff came with some of my gaskets.
    Sent from my LG G4 using Tapatalk.
    06 LaCrosse 57-79k sold;99 4dr GTP 134-138k sold;98 2dr GTP 183k parted;98 Regal 166-184k;04 GT2 204-206k sold;04 GTP 170-175k sold;09.5 G8 GT Sport 145k;09 G8 78-84k+;08 Prix 164k sold;06 Prix 168k sold;02 Regal 92k;09 G8 103k parted;04 GTP SpEd 139k parted;04 GTP 205k;'09 G8 105k parted;06 Prix 230k;04 CompG 138k
  3. #23 Re: Lifter Tick Questions
    the 4 corners of the block where the rubber and metal lim gaskets meet. a dab in all 4 corners on bare metal, then install the gaskets, then another dab in the corners smear it so its touching both gaskets.
  4. #24 Re: Lifter Tick Questions
    Jun 2015
    Okay, thanks!
  5. #25 Re: Lifter Tick Questions
    https://www.youtube.com/watch?v=J7Ay4PQpgZI
    Fast forward and skip a few things...but this should basically do the trick.
  6. #26 Re: Lifter Tick Questions
    Jun 2015
    On the lifters...., does the rolling thing need to be perfectly aligned on top of the cam?
  7. #27 Re: Lifter Tick Questions
    Well, it can't roll on it sideways....
    They only fit one way so you can't really mess it up.
  8. #28 Re: Lifter Tick Questions
    Jun 2015
    I see that now, lol, brain fart. Just don't wanna screw my engine up. XD
  9. #29 Re: Lifter Tick Questions
    Jun 2015
    Hey, so, how much 50/50 coolant should I dump into the radiator before starting it up? Then fill the coolant reservoir to the line.... Also, just run it for a few minutes before dropping the oil and putting some new stuff in to make sure all the particles are out? Probably change the oil filter then too?
  10. #30 Re: Lifter Tick Questions
    I never used the 50/50 crap, I do what's Scotty does and just dump 1 gallon of straight coolant then feel the rest of the radiator with distilled water
    04 Comp G.
  11. #31 Re: Lifter Tick Questions
    if theres old coolant in there you can flush it to water then add one gallon of full strength coolant to the rad.
    or just re fill it with 50/50, if you buy the full strength coolant, then use a old one gallon jug of what ever, split and top off both containers and now you have two gallons of coolant for the price of one.
    run it for a couple minutes, if the rockers are clapping like a freight train let it run till they stop making noise, ( 5 to 10 minutes) then change oil and the filter.
  12. #32 Re: Lifter Tick Questions
    Jun 2015
    It's all flushed, no coolant or water. Oh, okay.
  13. #33 Re: Lifter Tick Questions
    well the block holds a good gallon, unless you took the engine out and turned it over its still got coolant in it.
  14. #34 Re: Lifter Tick Questions
    Jun 2015
    Oh, so, we just drained it out the plug on bottom the rad, and whatever came out the hoses we disconnected. So, I'll just throw a full-strength in the rad and fill up the res with water.
  15. #35 Re: Lifter Tick Questions
    Jun 2015
    Sounds like I got a vac leak on the rear driver's side of the engine.... Hissing, sounds like air.
  16. #36 Re: Lifter Tick Questions
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    Brake booster?
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  17. #37 Re: Lifter Tick Questions
    Jun 2015
    I guess I'll have to Google what that looks like, lol.
  18. #38 Re: Lifter Tick Questions
    Oct 2014
    Frederick, MD
    The hose going from the big black pancake on the firewall to the intake manifold
  19. #39 Re: Lifter Tick Questions
    Jun 2015
    Oh, yeah, I checked that over.... Didn't appear to be it, I'll look over it more when I get home from work tomorrow.
  20. #40 Re: Lifter Tick Questions
    Jun 2015
    The O-ring that goes on the part of the brake booster hose that goes into the UIM looked old and crappy, but we didn't have any that were the right size. Used some silicone, seemed to work for a while, but now the air noise is back and it doesn't idle right. Guessing that was the issue then, getting an O-ring this week.
    Something that has me worried though, every so often when I start it I'll get a ticking noise for like 3/5 seconds, then it goes away. What's up with that?!
  1. Injector or lifter tick
    By Alexgp in forum Introductions/Noob Questions
    Last Post: 05-14-2016, 08:45 PM
  2. Lifter tick or something else?
    By 04gtpnoob in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-19-2016, 11:14 PM
  3. 3800 lifter tick
    By redynscire in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-27-2011, 08:00 PM
  4. Lifter tick?
    By My GTP 97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-22-2010, 01:03 PM
  5. Lifter Tick
    By 04CompG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-21-2008, 06:43 PM
