Thread: Black smoke. Rough idle
Results 1 to 15 of 15
  1. #1 Black smoke. Rough idle
    SE Level Member kenizzle36's Avatar
    Apr 2011
    Menasha, Wisconsin
    Hey guys and gals. Bought a 2000 gt the other day (for 150$) and was only needing a coil. So I replaced a coil. Started the car and it was running great. Slight tick but nothing I'm to worried about. Anyways got home from work last night went to start it again and it didn't wanna run was rough idle and blowing black smoke when on the gas. Anything I should check? I know most likely running rich. Just don't know what to do from here
    Sent from my SM-G900R6 using Tapatalk
    99 GP GT- Bosal mufflers, Custom intake.
  2. #2 Re: Black smoke. Rough idle
    Oct 2011
    Toledo, OH
    Black smoke is usually unburnt gas. Probably not running rich, probably missing a cylinder. Check wires and plugs but first check codes and see if you have a P030X code to tell you which cylinder.
    7"
  3. #3 Re: Black smoke. Rough idle
    Apr 2011
    Menasha, Wisconsin
    Alright. I have a code reader on the way. Hoping within a few days. Will check the code. Going to change the other 2 coils just because. Will pull the plugs tonight.
  4. #4 Re: Black smoke. Rough idle
    Check FPR.
    Check for vac leaks.
  5. #5 Re: Black smoke. Rough idle
    Apr 2011
    Menasha, Wisconsin
    Thanks blueguy. Will check that tonight.
  6. #6 Re: Black smoke. Rough idle
    Quincy, Mass
    How are the plugs and wires?
    Sent from my iPad using Tapatalk
    No more GP 04 Impala SS Indy:
  7. #7 Re: Black smoke. Rough idle
    Apr 2011
    Menasha, Wisconsin
    So far all junk. Think they're still factory wires and coils. I bought wires plugs and both the other coils. Fighting that at the moment. These boots do not wanna let go lol.
  8. #8 Re: Black smoke. Rough idle
    twist and rip em off, it dont matter if they break at this point. if it comes down to it, take a razor blade to the boots and peel em off.
  9. #9 Re: Black smoke. Rough idle
    Apr 2011
    Menasha, Wisconsin
    The metal shroud needs to come off too. Broke 3 of 3 lol
  10. #10 Re: Black smoke. Rough idle
    grab them with needle nose pliers rip them off and they go right in the trash can, do not re use them metal covers.
  11. #11 Re: Black smoke. Rough idle
    Apr 2011
    Menasha, Wisconsin
    Yea? Why is that?
  12. #12 Re: Black smoke. Rough idle
    they can cause misfires. you dont need them, or want them on there.
  13. #13 Re: Black smoke. Rough idle
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    mine haven't caused any misfires ...yet... lol
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  14. #14 Re: Black smoke. Rough idle
    Apr 2011
    Menasha, Wisconsin
    Good to know Scotty. Thanks. I'll take them off then. Got front done and just for the hell of it started the car. Just the 3 plugs the car sounds 100 times better. Rear and a oil change tomorrow
  15. #15 Black smoke. Rough idle
    Apr 2011
    Menasha, Wisconsin
    So. All plugs wires and coils changed. Fuel filter changed. Car starts idles perfect. Then eventually dies. Then won't start again. Fires up and dies right away.
  1. P0171 and P0300 Codes, Mildly Rough Idle, Rough on starts, Slightly Elevated Idle
    By nskyline34 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-17-2021, 07:49 PM
  2. oh no! gray smoke... rough idle :(
    By JohnJ89 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-02-2015, 09:36 PM
  3. Rough Idle with intermittent idle miss
    By 99GTPMLA in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2012, 12:12 PM
  4. 2000 gtp runnig rough and black smoke
    By cjrolke in forum General Tech Discussion
    Last Post: 11-01-2011, 01:38 PM
