Help all my coolant is leaking out of my overflow tube. WHAT could I use to stop my coolant from leaking out
Sent from my SM-N910T using Tapatalk
so the tank over flows? mine used to do that. blue devil stopped it, that engine later blew up, new engine, no longer happens.
and my head gaskets looked ok when i pulled the heads off.
id start with a new rad cap tho, they tend to fail with age.
well a durrr, put it back in now. thats what a over flow tanks does, takes coolant as the car gets hot and pushes it into the "over flow tank" hence the name. as the engine cools it sucks the coolant back in. why theres a hot and cold line on the tank.
OK so I tried to keep all of the coolant inside my radiator by plugging up the overflow hole but my car still overheated and died on me. So should I change the Thermostat?
was the coolant right to the edge of the lim, or dry in the hole?
was it a drilled t stat you put in? if it is drilled just top off the coolant and drive it and check the rad level the next few mornings and top off if need be. the drilled hole in the t stat lets the air out for ya.
