Thread: Coolant overflow leak
Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
  1. #21 Re: Coolant overflow leak
    GT Level Member Jason97GrandprixGT's Avatar
    Sep 2014
    New Orleans
    How to check both and make sure
    Sent from my SM-N910T using Tapatalk
  2. #22 Re: Coolant overflow leak
    your like helpless? got 2 eyes that work? fingers that can feel wetness?
  3. #23 Re: Coolant overflow leak
    Sep 2014
    New Orleans
    Lol I understand bro ill check when the engine get cooler
  4. #24 Re: Coolant overflow leak
    I feel like someone is trying to paint by numbers when they left the coloring book in a different country.
  5. #25 Re: Coolant overflow leak
    Sep 2014
    New Orleans
    Turns out the bottom heater hose has a big hole in it and was leaking out all my coolant
  6. #26 Re: Coolant overflow leak
    well there ya go. that one is fun to change too.
  7. #27 Re: Coolant overflow leak
    Sep 2014
    New Orleans
    I removed the clamp but the damn hose is not trying to come off
  8. #28 Re: Coolant overflow leak
    dont go all animal, you can crack the rad tube, cut the hose off close to the rad with a sharp razor, then use a small screw driver to pry the hose free from the rad.
    same goes for the engine side if thats glued on too.
  9. #29 Re: Coolant overflow leak
    Sep 2014
    New Orleans
    Its the hose that goes into the firewall
  10. #30 Re: Coolant overflow leak
    thats a heater hose, same deal cut the hose off stick a screw driver between the hose and tube and wiggle around it till its free and comes off.
    you can even cut a slit along the pipe and peel the hose off, those you can man handle more, cause they are metal.
  1. Will a coolant overflow bottle from a 99 fit onto a 97?
    By Doug 97 gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-29-2012, 02:26 PM
  2. Oil in Coolant overflow bottle
    By Oxfire in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-05-2012, 02:35 PM
  3. 97 coolant overflow tank
    By RedGrandprixgt53 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-30-2012, 04:09 PM
  4. Cleaning coolant overflow ......
    By Pepino in forum General Tech Discussion
    Last Post: 05-26-2010, 07:23 AM
