How to check both and make sure
Sent from my SM-N910T using Tapatalk
your like helpless? got 2 eyes that work? fingers that can feel wetness?
I feel like someone is trying to paint by numbers when they left the coloring book in a different country.
Turns out the bottom heater hose has a big hole in it and was leaking out all my coolant
well there ya go. that one is fun to change too.
I removed the clamp but the damn hose is not trying to come off
dont go all animal, you can crack the rad tube, cut the hose off close to the rad with a sharp razor, then use a small screw driver to pry the hose free from the rad.
same goes for the engine side if thats glued on too.
Its the hose that goes into the firewall
thats a heater hose, same deal cut the hose off stick a screw driver between the hose and tube and wiggle around it till its free and comes off.
you can even cut a slit along the pipe and peel the hose off, those you can man handle more, cause they are metal.
