Thread: Coolant overflow leak
Results 1 to 20 of 30
  1. #1 Coolant overflow leak
    GT Level Member Jason97GrandprixGT's Avatar
    Sep 2014
    New Orleans
    Help all my coolant is leaking out of my overflow tube. WHAT could I use to stop my coolant from leaking out
    Sent from my SM-N910T using Tapatalk
  2. #2 Re: Coolant overflow leak
    Buy a new one if it's leaking.
    Or you have bigger issue's if pressure is pushing coolant out.
  3. #3 Re: Coolant overflow leak
    Sep 2014
    New Orleans
    My radiator isn't leaking but something is pushing my coolant out and it's escaping through the overflow tube
  4. #4 Re: Coolant overflow leak
    so the tank over flows? mine used to do that. blue devil stopped it, that engine later blew up, new engine, no longer happens.
    and my head gaskets looked ok when i pulled the heads off.
    id start with a new rad cap tho, they tend to fail with age.
  5. #5 Re: Coolant overflow leak
    Sep 2014
    New Orleans
    Ok
  6. #6 Re: Coolant overflow leak
    Sep 2014
    New Orleans
    I took the over flow tank out so it's just the over flow tube hanging to the ground
  7. #7 Re: Coolant overflow leak
    well a durrr, put it back in now. thats what a over flow tanks does, takes coolant as the car gets hot and pushes it into the "over flow tank" hence the name. as the engine cools it sucks the coolant back in. why theres a hot and cold line on the tank.
  8. #8 Re: Coolant overflow leak
    Sep 2014
    New Orleans
    Oh ok but can I just plug up the hole by the radiator cap
  9. #9 Re: Coolant overflow leak
    no.
  10. #10 Re: Coolant overflow leak
    Sep 2014
    New Orleans
    I already plugged up the overflow hole with aluminium foil but I'll put my overflow tank back on when I get home
  11. #11 Re: Coolant overflow leak
    Sep 2014
    New Orleans
    OK so I tried to keep all of the coolant inside my radiator by plugging up the overflow hole but my car still overheated and died on me. So should I change the Thermostat?
  12. #12 Re: Coolant overflow leak
    how low is the coolant in the rad? is been pissing out for how long now?
    if its full try a t stat, make sure the fans work, temp sensors go bad.
  13. #13 Re: Coolant overflow leak
    Sep 2014
    New Orleans
    Its been pissing out for a while now it's been a few years since I replaced the thermostat
  14. #14 Re: Coolant overflow leak
    you got leg work to do then. put the tank back on, hook it up, fill it to the cold line, fill the rad, check the fans are working. and bleed the t stat for air.
  15. #15 Re: Coolant overflow leak
    Sep 2014
    New Orleans
    I installed the new thermostat now should I bleed the thermostat
  16. #16 Re: Coolant overflow leak
    was the coolant right to the edge of the lim, or dry in the hole?
    was it a drilled t stat you put in? if it is drilled just top off the coolant and drive it and check the rad level the next few mornings and top off if need be. the drilled hole in the t stat lets the air out for ya.
  17. #17 Re: Coolant overflow leak
    Sep 2014
    New Orleans
    What do you mean by drilled I just put the new thermostat in and bolted it back on
  18. #18 Re: Coolant overflow leak
    means its got a small hole in the plate. some come this way, and if not, you can drill your own hole.
  19. #19 Re: Coolant overflow leak
    Sep 2014
    New Orleans
    Oh OK I found a coolant leak at the back of the engine
  20. #20 Re: Coolant overflow leak
    near where? could be two things, rusted freeze plug, or one of the heater hoses is leaking.
  1. Will a coolant overflow bottle from a 99 fit onto a 97?
    By Doug 97 gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-29-2012, 02:26 PM
  2. Oil in Coolant overflow bottle
    By Oxfire in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-05-2012, 02:35 PM
  3. 97 coolant overflow tank
    By RedGrandprixgt53 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-30-2012, 04:09 PM
  4. Cleaning coolant overflow ......
    By Pepino in forum General Tech Discussion
    Last Post: 05-26-2010, 07:23 AM
