Thread: Pipe Degree for air ram intake?
Page 6 of 8 FirstFirst ... 45678 LastLast
Results 101 to 120 of 145
  1. #101 Re: Pipe Degree for air ram intake?
    GT Level Member Jason97GrandprixGT's Avatar
    Sep 2014
    New Orleans
    Car is back running like a champ thanks ppl
    Sent from my SM-N910T using Tapatalk
  2. #102 Re: Pipe Degree for air ram intake?
    Sep 2014
    New Orleans
    One last question what is this cable called and how should I adjust it
  3. #103 Re: Pipe Degree for air ram intake?
    cruise control cable, and your dont adjust it.
  4. #104 Re: Pipe Degree for air ram intake?
    Sep 2014
    New Orleans
    Quote Originally Posted by ScottyDoggs View Post
    How far should I bring it up because my car doesn't shift normally because of it
  5. #105 Re: Pipe Degree for air ram intake?
    does that cable lead to the tranny? if so all it does is pull it in or out of gear, has nothing to do with sifting down the road.
    once again, its not adjustable. the clip on the end can break, but that only affects it going into gear. or not going in gear or into park.
    if you would only get the car scanned. you'd have a good idea where to look. but telling you that is like beating a dead horse.
  6. #106 Re: Pipe Degree for air ram intake?
    Sep 2014
    New Orleans
    Lol I'm going get it scanned now my man
  7. #107 Re: Pipe Degree for air ram intake?
    best news ive heard in days. lol
  8. #108 Re: Pipe Degree for air ram intake?
    There's three cables in your pic.
    Throttle
    Cruise
    Trans
    None of them would directly affect shifting as long as gear selection works.
  9. #109 Re: Pipe Degree for air ram intake?
    Sep 2014
    New Orleans
    Throttle
    Cruise
    Trans
    Can you circle and name the cables in the picture for me
  10. #110 Re: Pipe Degree for air ram intake?
    Sep 2014
    New Orleans
    Just left autozone no codes popped up when they tested it
  11. #111 Re: Pipe Degree for air ram intake?
    odd cause you say the check engine light never comes on.
    the bare wires at the speed sensor. you fix them? that could be the issue.
    or that aftermarket maf too. these cars HATE them big time.
  12. #112 Re: Pipe Degree for air ram intake?
    Maybe the degree of your intake is incorrect.
  13. #113 Re: Pipe Degree for air ram intake?
    Sep 2014
    New Orleans
    The degree of my intake could cause stalling?
  14. #114 Re: Pipe Degree for air ram intake?
    Aug 2011
    'Merica
    Oh Bill...
  15. #115 Re: Pipe Degree for air ram intake?
    Sep 2014
    New Orleans
    The maf is oem and I put black tape over the wires. It's not dying on me like it did before but my car would still stall a bit after I come to a complete stop
  16. #116 Re: Pipe Degree for air ram intake?
    tapes not a fix, you need to cut the wires back till you get to clean shinny copper wire on both sides of the damaged wire, then solder in a new length of wire if needed to make up for the wire you took out.
    if its bare to the plug, you buy a new pig yail and solder it on.
  17. #117 Re: Pipe Degree for air ram intake?
    Sep 2014
    New Orleans
    I spliced the wires on with the new vss connector and wrapped it up with electrical tape. My abs light remains on now I'll go back over it tomorrow and get another connector from the junk yard
  18. #118 Re: Pipe Degree for air ram intake?
    Sep 2014
    New Orleans
    It's driving better though but my speedometer needle is still not working
  19. #119 Re: Pipe Degree for air ram intake?
    tapes not a good for a seal. it needs to be soldered and sealed with shrink tubing so its air and water tight.
  20. #120 Re: Pipe Degree for air ram intake?
    Sep 2014
    New Orleans
    Ok also the vss connector on my car is different from other vss connectors from other cars like impala and monte carlo with the 3.8 engine. Why is that
  1. Intake pipe/BOV questions...
    By GTPChristopher in forum Turbo
    Last Post: 12-16-2015, 04:59 PM
  2. 4" JMP or ZZP intake pipe
    By CrazyGuy03 in forum Wanted To Buy - Parts
    Last Post: 06-11-2015, 07:14 PM
  3. Intake pipe from a z3 turbo kit
    By Swiggles in forum Wanted To Buy - Parts
    Last Post: 06-01-2014, 08:26 AM
  4. 08 Altima 3.5 CVT w/Intake,test pipe,& tune
    By pontiacman22 in forum Track Sessions and Kills
    Last Post: 10-20-2008, 03:51 PM
