Thread: Threw a ROD !
Results 1 to 14 of 14
  1. #1 Threw a ROD !
    SE Level Member Denbow 99 GT's Avatar
    Dec 2014
    Dover Ohio
    So I had put 1500 miles around town on my newly finished 99 GT and decided to take it on a small road trip .... 150 miles in on the Pa. turnpike I started to loose power, exhaust sounded louder, small tapping to loud knocking then POOF, giant cloud of smoke, parts pinging off my new ZZP exhaust and coast to the side of the road DOA ! .... this all took about 15 sec. to happen.
    a tow, 4 days of storage, a recovery mission, and $500 later its back home.
    a question ... can this event make the engine twist ? I noticed today that the engine is defiantly twisted to the left when looking straight at it. all the oil is also on the left side, the drivers side is dry.
  2. #2 Re: Threw a ROD !
    bad engine mount will let the engine twist in the bay. you got bigger issues at hand tho.
  3. #3 Re: Threw a ROD !
    Maybe it spun a bearing, then it siezed really fast and force of the motor snapped the rod and out the side of the block it went.
  4. #4 Re: Threw a ROD !
    Kemmerer, Wyoming
    There is no way for an engine to twist, a bad motor and our transmission mount is much more likely
  5. #5 Re: Threw a ROD !
    Dec 2014
    Dover Ohio
    Quote Originally Posted by SgtMarshal View Post
    I'm not going to say its not a bad mount, but all mounts were replaced when we did the new tranny install .... basically the entire front suspension and mounts, with the exception of sub-frame mounts are new.
    I was wondering if the sudden STOP of the engine would carry enough torque to twist the engine in the mounting.
    I can get a pic. but if your looking at the engine straight on, the left side is forward, its very noticeable at the dog bones.
  6. #6 Re: Threw a ROD !
    Dec 2014
    Dover Ohio
    I was doing 75 on the highway when this happened ....
  7. #7 Re: Threw a ROD !
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
    junkyard motor time
  8. #8 Re: Threw a ROD !
    Dec 2014
    Dover Ohio
    Quote Originally Posted by JamesIvey24 View Post
    junkyard motor time
    was actually considering a remanufactured long block .... any good suggestions ? ........ just hate to waste $300 - $500 on a used one and throw another rod !
  9. #9 Re: Threw a ROD !
    id just go with a jy engine. do the lim gaskets, oil pan gasket if its wet, drop it in.
  10. #10 Re: Threw a ROD !
    Dec 2014
    Dover Ohio
    Quote Originally Posted by ScottyDoggs View Post
    I just scored a motor tranny combo from the next town over... out of a 03 bony ... 125000 .... $200 ....
    are there any issues with this swap ??
  11. #11 Re: Threw a ROD !
    Dec 2014
    Dover Ohio
    Quote Originally Posted by Denbow 99 GT View Post
    well scrap that idea .... went to pick it up and changed my mind ..... not exactly what was told to me, basically a BOAT ANCHOR ! and the search is on again
  12. #12 Re: Threw a ROD !
    May 2011
    Illinois
    you'll need to swap over your motor mounts and stuff.
  13. #13 Re: Threw a ROD !
    Dec 2014
    Dover Ohio
    is it a direct bolt up to my Tranny ?
  14. #14 Re: Threw a ROD !
    Bastard Reptile's Avatar
    Kansas City, MO
    Probably have to swap the oil filter housings as well, I think that they're different on the H body. Everything else should bolt up just fine.
  1. Wideband threw egr help
    By Timing in forum PCM Tuning
    Last Post: 09-05-2014, 02:33 PM
  2. Threw belt
    By Logan541 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-25-2014, 07:52 AM
  3. i think i threw a rod and or rod bearing.
    By Doug 97 gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-05-2013, 08:02 PM
  4. Video I threw together
    Last Post: 01-31-2010, 01:03 PM
  5. Threw a code!
    By TFBuckeye in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-08-2008, 06:06 PM
