Thread: Wideband threw egr help
Page 1 of 3 123 LastLast
Results 1 to 20 of 46
  1. #1 Wideband threw egr help
    gardner,mass
    So im trying to log my egr in my hpt and have it all wired up threw the center brown wire the the wire signal coming from wideband.
    Next i inserted a user defined pid with the function ([PID.2811]/0.5)+10
    I tried with sensor blank and also set as air fuel ratio :1
    Then i realised my egr min iat was set to 284* so i set it to -40
    Still saying unsupported.
    I also tried the second egr pid 2810 to see if it was different for 04+ with no results.
    Anyone have any other ideas?
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  2. #2 Re: Wideband threw egr help
    Feb 2009
    flintnasty MI
    Make sure you scan the egr voltage as well as have the user defined pid
  3. #3 Re: Wideband threw egr help
    gardner,mass
    as in set a histogram?
  4. #4 Re: Wideband threw egr help
    Feb 2009
    flintnasty MI
    I think you have to scan the voltage out in order to set a custom pid up? Either way make sure it returns voltage before messing with the custom part.
  5. #5 Re: Wideband threw egr help
    gardner,mass
    alright ima just try adding a egr pos pid to the primary table to atleast see if im getting voltage
  6. #6 Re: Wideband threw egr help
    gardner,mass
    Ok so im reading the egr pos pid just fine and when i press the throttle is moves with my wideband so something must no be written correctly. As stated the user defined pid is set as
    Abbrev: wb
    Sensor: Ive tried blank air fuel ratio and egr pos
    Units: (blank) (:1) (afr)
    Function:
    ([PID.2811]/0.5)+10
  7. #7 Re: Wideband threw egr help
    Feb 2009
    flintnasty MI
    Hmm so when you scan both of them the 1 works and the other doesnt eh. Must be a syntax error in hpt. I cant help much with hpt I have only made pids in torque and dhp
  8. #8 Re: Wideband threw egr help
    gardner,mass
    Yea exactly. Well thanks anyway dark atleast i know now its not the wiring and my egr(err wideband) is actually sending signal to the pcm. Now i just got to figure out a way to fix the pid
  9. #9 Re: Wideband threw egr help
    Arizona
    You have to insert egr voltage in your table display.
    Also throw in Afr hi res
    Shoot me an email with it attached I'll see if I can help layer on today
  10. #10 Re: Wideband threw egr help
    gardner,mass
    Quote Originally Posted by 91parkave View Post
    Ok i think i know what you meen. Ive been looking at guides online and none of them mentioned that. I g2g atm but if i cant figure it out ill hit you up later. Thanks
  11. #11 Re: Wideband threw egr help
    gardner,mass
    Ok so i got the pid to finally work cus i wasnt reading egr pos V in my table. I also got my gauge display and my graph to read it correctly aswell. But now im having troubles getting it to function in my histogram.
  12. #12 Re: Wideband threw egr help
    Feb 2009
    flintnasty MI
    Ok so I was right. You do have to scan the pid and the custom one right?
  13. #13 Re: Wideband threw egr help
    gardner,mass
    Yea you have to scan the egr pos voltage and then create a custom pid like i initially set up
  14. #14 Re: Wideband threw egr help
    Arizona
    Once you make your faux wideband pid you then need to make a Afr error histo using that pid number plugged into the equation. You have to make that your Afr error. Then put that in your table display as well.
    You can then use Afr error% against maf freq hz for your histo
  15. #15 Re: Wideband threw egr help
    Arizona
  16. #16 Re: Wideband threw egr help
    gardner,mass
    Ok so car is pretty much all set. Its running hell of alot better. Right now at wot im seeing roughly 19-21* of timing 10.5-11.5 afr and blips of 1-2* of knock once in awhile, fuel trims are pretty much average within 5% across the board. One issue though. For some reason when im doing wot runs my Wideband gauge will be locked at 10 where as hpt is reading 10.5-11.5. I synced them at idle and they were pretty much dead on, even when pressing the throttle. So now im unsure if im running rich or not. For sure feels like i gained power from the 12-13 * i was seeing befor. But my narrowband is lock at about 1000-1050 then im locked at 10.50 on hpt with the wideband,so does that seem accurate or is the gauge actually correct?
    Also 1 more thing why is it that my histogram reading my wb vs mass air flow freq above 7k in some hz here and there i see blanks once in a while?
  17. #17 Re: Wideband threw egr help
    Arizona
    U need to figure out your voltage offset. You can verify by turning the scanner on without the engine on. Seeing your actual voltage. Double check that against the voltage from the wideband. Usually its a .05 to .07 voltage drop.
  18. #18 Re: Wideband threw egr help
    gardner,mass
    Good call ill try that. thanks
  19. #19 Re: Wideband threw egr help
    Not sure which sensor you are using. Innovate suggests the .07 as well.
  20. #20 Re: Wideband threw egr help
    gardner,mass
    Im using the aem 30-4100 uego. Is there a chart or something i can go off? I have it set to .05+9.6 i think atm
  1. Threw belt
    By Logan541 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-25-2014, 07:52 AM
  2. i think i threw a rod and or rod bearing.
    By Doug 97 gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-05-2013, 08:02 PM
  3. Threw crankshaft sensor
    By Sesleeper in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-06-2011, 02:29 PM
  4. Video I threw together
    Last Post: 01-31-2010, 01:03 PM
  5. Threw a code!
    By TFBuckeye in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-08-2008, 06:06 PM
