Thread: i think i threw a rod and or rod bearing.
Results 1 to 5 of 5
  1. #1 i think i threw a rod and or rod bearing.
    GTX Level Member Doug 97 gtp's Avatar
    Sep 2011
    palm harbor florida
    sooooo my engine started to make a knock upon startup after it had sat for about 4 months. upon inspection it seems to be a rod knock and or thrown bearing i drained my oil and it is very mettalicy and i cut open my oil filter and it tons of metal particles. so im not sure if i should spend my time rebuilding my engine or just buy a used one. any opinions on what i should do and if there any good rebuild kits for a 97 gtp motor?
    that was in the bottom of my oil filter and i couldnt get a good of the oil but it looked like candy rootbeer paint.
    1997 GTP . repainted in jet black with blue pearl. rebuilt motor
    with vs cam ported heads and blower.
  2. #2 Re: i think i threw a rod and or rod bearing.
    Sounds like coolant got into the oil, and caused the spun bearing.
    A used short block is normally cheaper than full on machine shop work to rebuild a motor.
  3. #3 Re: i think i threw a rod and or rod bearing.
    Sep 2011
    palm harbor florida
    the oil wasnt milky at all there is now way the coolant got into the oil. my car never needed the lim gaskets to be done :P
  4. #4 Re: i think i threw a rod and or rod bearing.
    Sep 2011
    palm harbor florida
    does anyone know where i can find a long block l67 motor?
  5. #5 Re: i think i threw a rod and or rod bearing.
    Start calling junkyards.
  1. Fired up new engine threw some codes.
    By SleeperGS in forum General Tech Discussion
    Last Post: 09-28-2012, 08:08 AM
  2. Life just threw a couple mean jabs :(
    By RareGMFan in forum Off Topic Discussion
    Last Post: 07-31-2011, 01:48 PM
  3. Threw crankshaft sensor
    By Sesleeper in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-06-2011, 02:29 PM
  4. Video I threw together
    Last Post: 01-31-2010, 01:03 PM
  5. Threw a code!
    By TFBuckeye in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-08-2008, 06:06 PM
