Thread: Quick injector upgrade question
Results 1 to 20 of 25
  1. #1 Quick injector upgrade question
    Donating User
    Jul 2014
    Minnesota
    I am looking at a list of mods I would like to eventually complete for my 00 GT, DP, front powerlog, catback system(maybe), bigger TB with spacer, PCM and maybe the intake insert. My question is, is there a point where the stock injectors will need to be upgraded?
    00 Red GT - ZZP PCM, ZZP HV TB, TRANSGO kit, GMPP Sway Bars, Strut Tower Braces,
  2. #2 Re: Quick injector upgrade question
    Feb 2013
    37.295091, -121.930053
    Go top swap its the best bank for the buck
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  3. #3 Re: Quick injector upgrade question
    Kemmerer, Wyoming
    Not on a gt. You would have to top swap it or turbocharge it to need bigger injectors
  4. #4 Re: Quick injector upgrade question
    Feb 2013
    Haha beat ya to it
  5. #5 Re: Quick injector upgrade question
    A bigger throttle body and spacer are useless, you won't ever outflow them.
    Only use a spacer if you plan to use NOS or meth injection.
    Your NA car won't be able to max the fuel injectors with those mods.
  6. #6 Re: Quick injector upgrade question
    Kemmerer, Wyoming
    Haha beat ya to it
    But you didn't answer his question
  7. #7 Re: Quick injector upgrade question
    Donating User
    Jul 2014
    Minnesota
    Thank you that helps alot
  8. #8 Re: Quick injector upgrade question
    Kemmerer, Wyoming
    If you decide to top swap it, I have a harmonic balancer for sale for supercharged 3800's
  9. #9 Re: Quick injector upgrade question
    Donating User
    Jul 2014
    Minnesota
    I've have always been interested in the idea of the top swap but the amount of work seems daunting. In my browsing I remember seeing a sticky or complete write up on the swap but cannot seem to find it. Anyone help?
  10. #10 Re: Quick injector upgrade question
    Kemmerer, Wyoming
    Look in the l36 section of engines
  11. #11 Re: Quick injector upgrade question
    Donating User
    Jul 2014
    Minnesota
    It was right in front of my face, got it.
  12. #12 Re: Quick injector upgrade question
    Kemmerer, Wyoming
    I have a sale thread in the classifieds if you want more info.
  13. #13 Re: Quick injector upgrade question
    Donating User
    Jul 2014
    Minnesota
    Is it safe to say that this is way over priced?
    http://zzperformance.com/3800/superc...arger-kit.html
  14. #14 Re: Quick injector upgrade question
    Feb 2013
    Ye ah that's way over priced you can go to your local junk yard and pick up the head, blower and balancer for way less. Then get all the gaskets for about 150 and a few hours of your time then you can have more power
  15. #15 Re: Quick injector upgrade question
    Kemmerer, Wyoming
    You could probably find a used set of ported heads on here for about 500, stick an xp cam in it and enjoy the 300+ horse power at your wheels
  16. #16 Re: Quick injector upgrade question
    Donating User
    Jul 2014
    Minnesota
    ok, I have been offered a ported S/C and TB plus balancer and oil filter relocater kit for 800, what is ballpark for rest?
  17. #17 Re: Quick injector upgrade question
    Donating User
    Jul 2014
    Minnesota
    I guess to begin with, my motor has 128k, would a top swap be smart?
  18. #18 Re: Quick injector upgrade question
    Kemmerer, Wyoming
    you could get a set of stock L67 heads for 150 shipped, or find a local junkyard and should be able to get both heads for 100. then you would need the lower intake manifold, and that would be about 50. you would need to swap out your map sensor for an L67, probably find one of those for 50, then you would need a set of L67 injectors, and those would be about 40 or 50. then if you wanted to really make your top swap shine, you could add an XP cam, a new one is about 325, a set of 130 lb valve springs for 100, valve seals are about 20, valve cover gaskets are about 20, and modified valve spring retainers are about 20, and a new set of valve locks are about 20. you would need a double roller timing chain which is 130 for a new one, a machined oil pump cover for 40 or something. and that should just leave you needing all the gaskets necessary when changing all the parts.
    you would also need headers to maximize the airflow. you can get a new set of speed daddy headers for 250.
    at some point you will need some transmission work.
    someone correct me if im wrong.
    edit for additional info: a top swap at that mileage is fine.
  19. #19 Re: Quick injector upgrade question
    Feb 2013
    http://www.oreillyauto.com/site/c/de...r+adapter+seal for the oil
    http://www.oreillyauto.com/site/c/de...anifold+gasket for the lower intake manifold
    then you got engine oil, new head bolts and coolant plus belts soo maybe 250 bucks left in parts
  20. #20 Re: Quick injector upgrade question
    Donating User
    Jul 2014
    Minnesota
    wow, thank yo all for the info. Not sure if i just wanted to do a couple exhaust mods or go for the full top swap. I will post when I know
  1. L32 Injector Upgrade
    By andrewpetty24 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-07-2014, 11:07 AM
  2. quickly injector part question
    By tweeder in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-22-2013, 06:33 PM
  3. Modified GTP injector question ??
    By Ryan99639 in forum General Grand Prix Discussion
    Last Post: 09-17-2013, 09:12 PM
  4. injector swap question
    By riceburner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-02-2009, 05:23 PM
  5. SES Code after injector Upgrade
    By FastKatt in forum PCM Tuning
    Last Post: 05-13-2008, 08:27 PM
