Thread: Modified GTP injector question ??
Results 1 to 11 of 11
  1. #1 Modified GTP injector question ??
    SE Level Member Ryan99639's Avatar
    Feb 2013
    Rockford
    Ok so I need to replace my fuel injectors. I will be intercooling and going around a 3.0 pulley in the future. But for right now should I go with stock or just upgrade in advance. Will the car run the same with bigger injectors without pushing the power right off the bat? Do I need to do anything or just install them and be good to go? Thanks
    BOOSTIN
  2. #2 Re: Modified GTP injector question ??
    GT Level Member mkyota1's Avatar
    Daytona, florida
    You can go bigger injectors anytime you want but you will have to tune for them. You can't throw them in with no tune.
  3. #3 Re: Modified GTP injector question ??
    Feb 2013
    Rockford
    Thanks that's exactly what I was looking for, think I'm gonna go with the used ones that are rebuilt from zzp. It's only like 150 and they guarantee them
    BOOSTIN
  4. #4 Re: Modified GTP injector question ??
    Banned
    CT
    I would go straight to the 60s... spending money on stock injectors would be a huge waste of time and money.
  5. #5 Re: Modified GTP injector question ??
    Feb 2013
    Rockford
    Yeah but I need something to put in the car to drive up until I do more performance mods. And I don't have a tuned PCM yet. Would #60s be over kill? I'm shooting for the 300whp goal without doing internals
    BOOSTIN
  6. #6 Re: Modified GTP injector question ??
    Florida
    No need to do internal work, though a cam would greatly help.
    I don't see any reason to buy stock injectors. I would go with either 42.5 or the 60s. If not, there are people selling their stock injectors for much less than ZZP.
    No sense in dropping $150 on stock injectors, when for $200-250 you can get the ones you want.
  7. #7 Re: Modified GTP injector question ??
    Feb 2013
    Rockford
    Ok that makes sense Maby ill just get the 42.5s and call it a day, then I have to get a reprogrammed PCM to go with those correct?
    BOOSTIN
  8. #8 Re: Modified GTP injector question ??
    GTP Level Member tms8582's Avatar
    Washington Michigan
    I agree with the others to go with the bigger ones. Stock won't deliver enough fuel for your 3.0 and you might run lean. 42.5's will be enough but 60's will give you more room in the future. You will need a tune fore sure. When I installed 60's and a walbro fuel pump for my e85 conversion I just had intense send me a ball park tune so I could drive down for the dyno tune.
    Stage 1 Comp Cam / 105 Springs / Yella Terra 1.7's / SLP Headers / Ported heads / 255 Walbro fuel pump / Siemans 60# Injectors / 2.8 Pulley / 180 stat, 104 AL's / Intense e85 tune / 3" ZZP exhaust / GXP seats / KYB Coilovers /
  9. #9 Re: Modified GTP injector question ??
    Feb 2013
    Rockford
    Ok. Maby u can answer another question for me. For me to get a dyno tune Do I just go in and get it done. Or do I have to have a programmer or PCM for them to flash or anything like that.?
    BOOSTIN
  10. #10 Re: Modified GTP injector question ??
    Florida
    You'll need to find a shop with the software to tune a stock PCM. Just call around and tell them you have a stock PCM that needs to be unlocked and dyno tuned.
    If they cannot do it, the should know who in the area can.
  11. #11 Re: Modified GTP injector question ??
    Washington Michigan
    I know of two places within 150-200 miles from me. ZZP in western Michigan and Intense (dyno motor sports) in central Ohio. You may be able to get a real close tune mail order from intense though. They have a ton of experience and so many files on record. I'd give them a call or email.
  1. injector wire diagram or question
    By TeacherCreature in forum General Tech Discussion
    Last Post: 10-13-2011, 12:26 AM
  2. injector swap question
    By riceburner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-02-2009, 05:23 PM
