Thread: Idle Problem when cold
Results 1 to 7 of 7
Threaded View
  1. #2 Re: Idle Problem when cold
    SE Level Member Rockhound's Avatar
    Dec 2010
    Maryland
    Quote Originally Posted by Rockhound View Post
    Have a 1995 Grand Prix GTP 3.4 DOHC and when I first start the car when it's cold outside the motor will pulsate to 2500rpm and then go down to around 500rpm then go back up to 2500 rpm's until it's warmed up then it runs and idle's fine. Any idea on what it could be that is causing that . Check engine comes on when it's at low idle ,, and almost ready to stall then goes up again . Give it gas and the light goes off. A friend of mine is going to check the code next weekend when he is in town but trying to see what you guys think it may be . With the car warmed up I unplugged the MAF while running and the idle went up and plugged it back and idle went back down, so i'm thinking thats ok. Could it be the IAC? I unplugged the IAC while running and no change in the idle.
    Thanks
    Well just to let anyone who is interested in this problem,, it was the LIM gasket and had them replaced ( upper & lower )problem solved!!!!!!! runs and idles great
  1. Slow Acceleration when engine is cold from idle
    By dblisle in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-12-2012, 11:30 AM
  2. 1998 GTP will not idle cold and revs to 1500rpm by itself when warm.
    By flyerboy101 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-25-2012, 04:35 PM
  3. why is my idle so low on cold start and sometimes fully warm?
    By 04silvercompg in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2012, 02:49 PM
  4. stalled at idle in cold and some scanner screenshots
    By hitnf in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-19-2012, 07:14 PM
  5. Cold Idle Miss
    By farmtwin in forum 3.4L V6 (LQ1) DOHC
    Last Post: 08-18-2010, 09:04 AM
