Thread: Slow Acceleration when engine is cold from idle
Results 1 to 10 of 10
dblisle Slow Acceleration when engine... 10-08-2012, 09:12 PM
Scottydoggs Re: Slow Acceleration when... 10-08-2012, 09:15 PM
dblisle Re: Slow Acceleration when... 10-08-2012, 09:25 PM
Scottydoggs Re: Slow Acceleration when... 10-08-2012, 09:51 PM
dblisle Re: Slow Acceleration when... 10-09-2012, 11:37 AM
dblisle Re: Slow Acceleration when... 10-09-2012, 11:20 AM
Scottydoggs Re: Slow Acceleration when... 10-09-2012, 11:27 AM
dblisle Re: Slow Acceleration when... 10-09-2012, 12:12 PM
Scottydoggs Re: Slow Acceleration when... 10-09-2012, 11:46 AM
dblisle Re: Slow Acceleration when... 10-12-2012, 11:30 AM
  1. #1 Slow Acceleration when engine is cold from idle
    SE Level Member dblisle's Avatar
    May 2012
    Keene, NH
    Hey guys,
    I'm back and I replaced the Boost Bypass Solenoid, the MAF, and the EGR Purge canister but I'm still having issue with accelerating from idle when the engine is cold. The check engine light is still on with the same issues, Could the issue be the Coolant Temp Sensor or an O2 sensor about to crap out on me?
    -Dave
  2. #2 Re: Slow Acceleration when engine is cold from idle
    whats the code? have you had the car scanned for codes? if not get it scanned, post the code.
  3. #3 Re: Slow Acceleration when engine is cold from idle
    May 2012
    Keene, NH
    p0102, p0443, P0243
  4. #4 Re: Slow Acceleration when engine is cold from idle
    if you unplug the maf does it run better?
    check the wires to the plug to the maf for cracks or any bare wire showing, a bad wire will cause the same code.
  5. #5 Re: Slow Acceleration when engine is cold from idle
    May 2012
    Keene, NH
    I've upload engine images to my photobucket account. Pictures by dblisle - Photobucket
  6. #6 Re: Slow Acceleration when engine is cold from idle
    May 2012
    Keene, NH
    I unplugged the MAF and there was no change.
  7. #7 Re: Slow Acceleration when engine is cold from idle
    if the wires look ok, then check all the fuses as well, in the car and under the hood, one of them does power the maf. so ive read here, never had to find it myself yet.
  8. #8 Re: Slow Acceleration when engine is cold from idle
    May 2012
    Keene, NH
    I found the emissions fuse broken and replaced it. When I take the car out next I'll see if the issue has gone away.
  9. #9 Re: Slow Acceleration when engine is cold from idle
    those pics dont say anything.
    you need to physically take the plug off the maf, top of the TB, and bend the plug end back look for cracks or bare wire showing, also check your fuse box for blown fuses.
    un wrap the wires, look at each one.
  10. #10 Re: Slow Acceleration when engine is cold from idle
    May 2012
    Keene, NH
    Looks like switching out the fuse solved the issue.
  1. Rpms drop under slow acceleration at 45mph
    By Bluemagic in forum General Tech Discussion
    Last Post: 04-29-2012, 07:31 PM
  2. Bucking on acceleration and stumbling idle at cold start
    By 1999GrandPrix in forum General Tech Discussion
    Last Post: 02-08-2012, 02:21 PM
  3. engine idle rough, acceleration bad
    By ksredryder in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-30-2010, 08:30 AM
  4. Slow Acceleration 3800 Series III in Fiero
    By D2inDFW in forum PCM Tuning
    Last Post: 03-27-2009, 11:37 PM
  5. 98 grand prix slow acceleration
    By jeffster in forum General Tech Discussion
    Last Post: 03-27-2009, 05:15 AM
