Thread: Engine problem 3.4L dohc
Results 1 to 5 of 5
sheepeater Engine problem 3.4L dohc 05-04-2010, 08:28 PM
tpeck88 Re: Engine problem 3.4L dohc 07-05-2010, 05:18 PM
Viper Re: Engine problem 3.4L dohc 09-08-2010, 04:31 PM
CTKGP09 Re: Engine problem 3.4L dohc 09-08-2010, 07:00 PM
Viper Re: Engine problem 3.4L dohc 09-08-2010, 11:49 PM
  1. #1 Engine problem 3.4L dohc
    guelph
    Car has rough idle at idle and hesitation at speed on throttle at 4000rpm check engine light comes on. any ideas??
  2. #2 Re: Engine problem 3.4L dohc
    Jul 2010
    MN
    I was told that a bad fuel pump regulator is what gives you that, and in park my car hits a rev limit at 4000rpm for some reason but if i shift into neutral it goes back to normal..so idk, try it
  3. #3 Re: Engine problem 3.4L dohc
    Jan 2009
    On This Planet...
    check the IAC. maybe it`s fouled.
    the 4000 rpm limit is "produced" from the knock sensor IIRC.
  4. #4 Re: Engine problem 3.4L dohc
    Willoughby, Ohio
    so people reply in 2 month intervals now?
  5. #5 Re: Engine problem 3.4L dohc
    Jan 2009
    On This Planet...
    Quote Originally Posted by CTKGP09 View Post
    had a starter problem...
    better late than never- isn`t it?
  1. Grand prix 3.4 Dohc help please
    By Minnesotawhite in forum 3.4L V6 (LQ1) DOHC
    Last Post: 03-09-2010, 09:27 PM
  2. Engine swap - 96' 3.4l DOHC out, '93 3.4l DOHC
    By csbrown in forum 3.4L V6 (LQ1) DOHC
    Last Post: 11-11-2009, 04:47 PM
  3. anyone with good knowledge of the 3400 DOHC?
    By Reppusmic in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-26-2009, 05:00 PM
  4. problem with engine light?
    By CheeWee in forum General Tech Discussion
    Last Post: 07-07-2009, 01:29 AM
  5. Engine problem???
    By WHITEHORSE in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-07-2009, 11:11 PM
