Thread: 1994 pontiac grand prix se timing belt questions
Results 1 to 7 of 7
  1. #1 1994 pontiac grand prix se timing belt questions
    washington twp
    This was my buddies car, I bought it off of him for 300 bucks, the car is in great condition cosmetically, but the timing belt shredded, I am going to fix the issues and sell the car to make some extra money. My question is what would be the best route to go about for diagnosing? I was thinking i can pull the engine, pull the heads off and inspect the valves and pistons for any damage, then go from there. I don't want to put a new timing belt on to find out the valves are bent or something. Any tips on removing the engine? I didn't take too hard of a look at how it is mounted, but it seems the motor and tranny both mount to the subframe, so I was thinking I could just drop the subframe and then separate the motor and tranny, and tear into the motor, but now that i think about it, I do not have a lift so i doubt there will be enough clearance to drop the subframe and maneuver the sub frame from underneath the car. I am just wondering what the best way is to remove the engine, so if anyone can give me some pointers on that, I would appreciate it!
  2. #2 Re: 1994 pontiac grand prix se timing belt questions
    an SE doesnt have a timing belt since it has a 3100. it has a timing chain. if you had a GTP that had the DOHC 3.4, then you'd have a timing belt.
    pulling the motor isnt hard, the engine bay is pretty damn big for the motor. pull it from the top, 100% easier than dropping the sub frame.
  3. #3 Re: 1994 pontiac grand prix se timing belt questions
    washington twp
    well im positive it has a timing belt because I looked at it today, so maybe the previous owner installed a different engine in it. because the intake says 3400 series.
  4. #4 Re: 1994 pontiac grand prix se timing belt questions
    washington twp
    also im pretty sure its not a gtp because aren't gtp's supercharged?
  5. #5 Re: 1994 pontiac grand prix se timing belt questions
    GTX Level Member Biohazed's Avatar
    Philadelphia, Pennsylvania, United States
    OK in 1994 the general rule of thumb is the SE came with the 3.1 and the GTP came with the 3.4 however there were some SE's built with the 3.4 although they are not common. and the 1st gen GTP's are not Supercharged, they were only supercharged after 1997
    *image too tall*
    BMR F + R Strut Bars - Falken Torque V 18's - JVC S900 - Kicker C10's - Spyder Projectors, Wizaird,
  6. #6 Re: 1994 pontiac grand prix se timing belt questions
    washington twp
    ok, so i must have one of those uncommon SE's with the 3.4 then. Alright guys I appreciate the quick responses, I don't have the car yet, i gotta borrow a trailer because this thing doesn't run. If i have any more questions I will ask
  7. #7 Re: 1994 pontiac grand prix se timing belt questions
    SE Level Member Teardrop's Avatar
    Indiana
    So how did it go? Also, is the engine, the 3100, a non-interferance one or not?
    94 Grand Prix GTP, 3.4
  1. 1994 Grand Prix - Limp Mode
    By TexasSteve58 in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 05-16-2010, 06:31 AM
  2. 1994 Pontiac Grand Prix air silencer removal
    By danmead12 in forum General Tech Discussion
    Last Post: 10-27-2009, 03:18 AM
  3. 1994 Grand Prix SE Front Modification Possible?
    By KobAil in forum Visual/Body Modifications
    Last Post: 01-09-2009, 08:38 AM
  4. location of heater inlet hose on 1994 grand prix?
    By bimple in forum General Tech Discussion
    Last Post: 01-01-2009, 06:37 PM
  5. 1994 Grand Prix Transmission Help!
    By mfalk22 in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 08-25-2008, 11:41 AM
