Thread: Pulley Problem
Results 1 to 4 of 4
  1. #1 Pulley Problem
    SE Level Member Davis909's Avatar
    Oct 2014
    Last night my serpentine belt started squealing. Got up today to give it a look and it had mostly snapped; I figured the Oklahoma temperature changes had gotten to it. Bought a new one and installed it no problems, but when I turned the car on, same noise.
    Upon further inspection, I realized one of the pulleys was no longer turning. I don't even know the name of this one. Could someone tell me the actual name for this specific part, and if possible, some suggestions as to what the problem may be? It's locked in pretty good.
    Pulley Problem Attached Images
  2. #2 Re: Pulley Problem
    Thats the water pump pulley.
    If that is no longer spinning, the water pump has siezed and needs replacing.
  3. #3 Re: Pulley Problem
    Oct 2014
    Quote Originally Posted by fivefingerdeathpunch View Post
    thats the water pump pulley.
    thank you!
  4. #4 Re: Pulley Problem
    They are super easy to replace.
    Remove the pulley, then remove the 6 bolts holding the water pump on. Remove it and clean the surface on the housing nicely, install the new pump with gasket and you're good to go.
    Just bleeding the cooling system is needed after that.
  1. Pulley install problem
    By JB122894 in forum General Grand Prix Discussion
    Last Post: 11-08-2013, 07:39 PM
  2. Belt shredded, pulley problem?
    By mckillin in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-14-2012, 07:59 AM
  3. 1999 gtp 3.4 pulley supercharger problem
    By gtpzzp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2011, 02:58 PM
  4. pwr steering pulley re-install problem
    By Grand Prix1 in forum Off Topic Discussion
    Last Post: 10-26-2010, 10:26 PM
  5. Pulley Problem
    By sdavis11b in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-13-2010, 05:54 PM
