Thread: Pulley install problem
Results 1 to 3 of 3
  1. #1 Pulley install problem
    SE Level Member JB122894's Avatar
    May 2012
    Illinois
    i was installing a 3.4 inch pulley with the pulley boys pulley puller and installer. i got the old one off. When i started installing the new one, it didnt go on all the way and the part that goes into the shaft fell out and every attempt to put it in farther is unsuccesful and i cant get it to go on. if you can help thatd be great
    1997 Grand Prix GTP
  2. #2 Pulley install problem
    Are you referring to the little m8 stud that goes onto the end?
    http://shop.zzperformance.com/store/...ler-Parts.aspx
    04 Comp G.
  3. #3 Re: Pulley install problem
    May 2012
    Illinois
    Yes, the supercharger shaft got completely stripped by the m8 stud. My father tapped it out though, then we used a threaded rod, washers and bolts and went right on. Thanks for the response
    Sent from my SAMSUNG-SGH-I337 using Tapatalk
    1997 Grand Prix GTP
  1. Pulley install dilemma
    By kurupt305 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-29-2013, 07:42 AM
  2. How hard is it to install a plog and 3.4 pulley
    By GMCARS4LIFE in forum General Tech Discussion
    Last Post: 02-07-2011, 06:40 AM
  3. pwr steering pulley re-install problem
    By Grand Prix1 in forum Off Topic Discussion
    Last Post: 10-26-2010, 10:26 PM
  4. ==> H@LP w/ TENSIONER Pulley Removal & Install Please <==
    By KevSorbo in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-30-2009, 08:14 PM
