You can jack it up on the metal subframe, I choose the 1 of the corners where the control arm bolts into the subframe and jack it up high enough for me to squeeze under there, I place the jack stand either under the subframe area or under that sides control arm just incase. Personally I don't care to get both front tires off the ground, I'm alright with not getting that last 1/4th of a quart of old oil from the one corner out when I only jack up one side.
