Thread: Transmission fluid change, Dealership or Typical Oil Change place?
Results 1 to 16 of 16
  1. #1 Transmission fluid change, Dealership or Typical Oil Change place?
    Jul 2010
    Canada
    Just wondering if I get a transmission fluid change whats the difference between the dealership and your typical oil change place. What are the pros and cons?
    I usually go to the dealership but it takes hours and costs double.
    Also how often should you do this when you get over 200,000 kms (120,000 miles)
  2. #2 Re: Transmission fluid change, Dealership or Typical Oil Change place?
    GTX Level Member hensleya1's Avatar
    Jun 2013
    Beavercreek, OH
    bjornbjorn--
    If you've got a place to do it, do it yourself. You can get any trans filter at your local AutoZone/OReilly's/Advance/NAPA/etc for ~10 bucks and 8 quarts of trans fluid for $25 at Wally World. Just make sure the filter comes with a gasket.
    Pull the 15 or so bolts off the old filter, pull that guy out, clean out the pan (especially the little magnet that catches all the metal shavings), replace, refill with 8 quarts of trans fluid, and you're good to go. Cost out the door is $40, max $50 if you get the good stuff.
    Every 50,000 miles (80,000km) is a good rule of thumb, but divide that in half if your car runs hot (over 200*). Anything above 200 or so and the trans fluid breaks down, giving you that burnt smell.
    2003 GT Limited Edition 199k - The $600 winter beater.
    2004 Buick LeSabre 172k - Top Swapped, 3.5 pulley, 1.9 rockers, SLP headers... still slow...
    MAKE AMERICA FAST AGAIN!
  3. #3 Re: Transmission fluid change, Dealership or Typical Oil Change place?
    SWPA
    Quote Originally Posted by hensleya1 View Post
    bjornbjorn--
    Unfortunately, you won't get 8 quarts for $25. Even at Wally World you are looking to spend $30 minimum on 8 qts of trans fluid.
  4. #4 Re: Transmission fluid change, Dealership or Typical Oil Change place?
    Dec 2012
    Where 4T65E's were born
    I agree. He quoted it a little low.
    it's $16.87 for a 4 quart jug of dex 3 at walmart, so around $34 for fluid.
    Sold.
  5. #5 Re: Transmission fluid change, Dealership or Typical Oil Change place?
    the cost and the time like you said.
    you can do it your self for under 50 bucks in your driveway. depending on your year use what ever dex fluid you need. dex 3 for 97-03 dex 6 for 04 up) cheap stuff is ok really. walmart brand is cheap.
    as far as when to service the tranny.....your late to the party already. depending an where you live, (hills or flat ground) you can start at 50,000 miles. 30,000 if you going up hills a lot or beating the snot out of it.
  6. #6 Re: Transmission fluid change, Dealership or Typical Oil Change place?
    Dec 2012
    The owners manual says up to 100k if never in "severe" driving conditions. But they also say 12k miles on conventional motor oil max, so...50k sounds good on trans. For me, it was $18 for a good wix filter, and it's $16.87 for a 4 quart jug of dex 3 at walmart, so around $34 for fluid. That's just over 50, but I needed a little more than 8 quarts, so I went ahead and bought another 4 quart jug to top off when needed. Also many people will argue the stock trans filter is perfectly re-usable as long as you clean it, so you can get just the filter, and not the filter kit. But it's really easy. All you need is a 10mm socket and ratchet, as well as a drain pan and some rags. That's all that's needed. (jack and jack stands too)
    Sold.
  7. #7 Re: Transmission fluid change, Dealership or Typical Oil Change place?
    or car ramps. i think everyone either has a set or knows some one who does. and ramps are rather cheap when on sale.
  8. #8 Re: Transmission fluid change, Dealership or Typical Oil Change place?
    Dec 2012
    I honestly don't think GP's would make it up without destroying the front bumper, especially the ones I've got.
    Sold.
  9. #9 Re: Transmission fluid change, Dealership or Typical Oil Change place?
    you need a few boards to drive up on first, then have the ramps at the end of the boards.
  10. #10 Re: Transmission fluid change, Dealership or Typical Oil Change place?
    GTP Level Member tms8582's Avatar
    Washington Michigan
    Im surprised nobody warned this guy not to get a trans flush. Some oil shops want to flush your trans. Most would advise against this and only service the trans with a pan drop and filter change. Google or search this forum for a how to...
    Stage 1 Comp Cam / 105 Springs / Yella Terra 1.7's / SLP Headers / Ported heads / 255 Walbro fuel pump / Siemans 60# Injectors / 2.8 Pulley / 180 stat, 104 AL's / Intense e85 tune / 3" ZZP exhaust / GXP seats / KYB Coilovers /
  11. #11 Re: Transmission fluid change, Dealership or Typical Oil Change place?
    St. Louis
    OP- If you do this yourself be sure that the rubber o-ring is out of the case when you remove the old filter. If it doesn't come out with it then just use a pick and grab it out of the bore.
  12. #12 Re: Transmission fluid change, Dealership or Typical Oil Change place?
    Jul 2010
    Canada
    So I dont want a flush just a pan drop and filter change? How come not the flush?
  13. #13 Re: Transmission fluid change, Dealership or Typical Oil Change place?
    yeah dont ever flush it, not with high miles.
    when the tranny gets old removing all the fluid takes what clutch material is in the fluid out of the tranny, then the tranny dies.
    dropping the pan only removes 1/2 the fluid. and is way safer then a flush.
    if you owned it from new and flushed it every 30,000 miles you would be safe. but this is not the case.
  14. #14 Re: Transmission fluid change, Dealership or Typical Oil Change place?
    Washington Michigan
  15. #15 Re: Transmission fluid change, Dealership or Typical Oil Change place?
    If you do end up taking it somewhere, just make sure the machine is just a fluid exchanger and not a flusher.
    My work has a machine that uses the transmissions pump itself to pump in new fluid and remove the old, it takes 12-14 quarts per time to make sure new fluid has gone all the way through.
  16. #16 Re: Transmission fluid change, Dealership or Typical Oil Change place?
    Dec 2012
    But these systems don't usually touch the filter. They use the trans lines as a lazy way to avoid dropping the pan.
    Sold.
  1. Tools/Materials needed for trans fluid change and filter change
    By JDrach in forum General Grand Prix Discussion
    Last Post: 12-10-2012, 07:47 AM
  2. Should I change my fluid?
    By indygrandprix in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-14-2012, 01:31 AM
  3. Transmission Fluid - 173K..To change or not to change, that is the question
    By 99XC600 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-01-2012, 10:03 PM
  4. Tranny Fluid - To change or not to change.
    By midrange in forum General Tech Discussion
    Last Post: 02-15-2012, 11:44 AM
  5. Transmission fluid change
    By 2000GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-06-2008, 03:42 PM
