Thread: HELP!!! 04 comp g pouring transmission fluid
Results 1 to 15 of 15
  1. #1 HELP!!! 04 comp g pouring transmission fluid
    Oct 2015
    Indiana
    Ok so i recently picked up this car off the original owner, and he informed me that it had never had the transmission fluid changed (140k) so I wanted to change it..it shifted fine before but i figured it was cheap insurance..fluid wasnt burnt but was deffinatly at the end of its life..so i dropped the pan cleaned everything up bought an oem gasket and filter..poured 4 quarts in and no leak..put another 3 in and it is pouring out of the dip stick tube...so im stumped...i start the car and it quits leaking but as soon as i shut it off boom leaking...mind you it didnt leak a bit before and i didnt mess with the tube at all..so heres my question...is 7.5 quarts too much? i read thats what it needs after a pan and filter change but idk why it would be leaking so bad all of a sudden..if it is the tube seal how to i change it?
  2. #2 Re: HELP!!! 04 comp g pouring transmission fluid
    Pouring out the bottom near the transmission or is it pushing it's way all the way up the tube and out?
  3. #3 Re: HELP!!! 04 comp g pouring transmission fluid
    Oct 2015
    Indiana
    out of the bottom
  4. #4 Re: HELP!!! 04 comp g pouring transmission fluid
    Oct 2015
    Indiana
    its just so weird that it didnt leak before the pan drop
  5. #5 Re: HELP!!! 04 comp g pouring transmission fluid
    hangover park IL
    the spot welds that hold the dipstick tube to the mounting bracket are known to rust out/break and cause leaks, though this leak point is not usually leaking until driving or while adding fluid
    ~James~ Psychotic Gearhead
  6. #6 Re: HELP!!! 04 comp g pouring transmission fluid
    Oct 2015
    Indiana
    how do i remove the dipstick tube? to replace the seal? is the 7 quarts right?
  7. #7 Re: HELP!!! 04 comp g pouring transmission fluid
    Mar 2014
    Tucson
    Does it have headers?
    I ask because, I recently had something similar happen when I helped a friend do a pan drop, filter, shiftkit install. Got everything all buttoned up, began to add fluid and same thing.... About 20% of what he dumped in ended up on the floor. Turns out, the dipstick tube was laying on the headers and over time, actually rubbed a hole clean through.
  8. #8 Re: HELP!!! 04 comp g pouring transmission fluid
    Oct 2015
    Indiana
    No headers, it doesn't even leak out that bad while pouring it in, it's after that it starts leaking bad, it really feels like I put too much in or something
  9. #9 Re: HELP!!! 04 comp g pouring transmission fluid
    hangover park IL
    uh what does the dipstick level say while its running
  10. #10 Re: HELP!!! 04 comp g pouring transmission fluid
    Oct 2015
    Indiana
    Basically what I'm needing to know is how to remove the dipstick..I see the bolt but it looks like a pain to get to..is there an easier way to get it off? There is very little room..
  11. #11 Re: HELP!!! 04 comp g pouring transmission fluid
    Oct 2015
    Indiana
    I really don't want to start it as it only has about 4 quarts in it..it's on ramps but with engine off its reading right at the add a pint mark
  12. #12 Re: HELP!!! 04 comp g pouring transmission fluid
    you take that 10 mm bolt out, then from the top, pull the tube out. have a pan under the tube as fluid may come out depending on just how low you are when you pull the tube out.
  13. #13 Re: HELP!!! 04 comp g pouring transmission fluid
    Oct 2015
    Indiana
    I got it but boy it wasn't easy, heat shield had to come off egr valve and bolt is at an angle so about 2ft of extension with a swivel anr it finally is out
  14. #14 Re: HELP!!! 04 comp g pouring transmission fluid
    Oct 2015
    Indiana
    Fixed! Used a Dorman 65113 seal and no more leaks..transmission shifts great
  15. #15 Re: HELP!!! 04 comp g pouring transmission fluid
    nice. odd the seal went bad when you didnt touch it. unless it was already low from leaking out before you got the car.......
  1. transmission fluid
    By Charged4Door in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-29-2014, 12:57 PM
  2. 2004 GTP transmission vs GTP Comp G transmission
    By Jordan in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-06-2014, 12:33 PM
  3. Replacing CV shaft and trans fluid pouring out
    By ggsz28 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-03-2011, 12:51 PM
  4. transmission fluid
    By dave2002GP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-19-2010, 09:01 PM
  5. Transmission fluid
    By ChevMan92 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-23-2010, 07:54 PM
