Thread: Trans question, sitting for almost a year
Results 1 to 7 of 7
  1. #1 Trans question, sitting for almost a year
    Keller,TX
    Car has been sitting for almost a year, since the motor died. I've got a engine that I'm ready to drop in but my worry is the transmission. Anything I should do on the day i start her up to insure the trans isn't damaged? Am I worrying about nothing?
  2. #2 Re: Trans question, sitting for almost a year
    Worrying about nothing. Just make sure you support the passenger end of the trans when you yank the motor. That way you won't damage the axle boot or output seal on the trans.
  3. #3 Re: Trans question, sitting for almost a year
    Keller,TX
    Can you swap the motor from the top? I was gonna drop the subframe. Wasn't sure if there was enough room for the engine to slide over to pull it from the top.
  4. #4 Re: Trans question, sitting for almost a year
    Antioch, IL
    you can pull engine and trans out the top if you wanted to, engine is a breeze out the top
    2009 Challenger SRT8
    Expert at being gay.
  5. #5 Re: Trans question, sitting for almost a year
    At the top middle of the screen is a magnifying glass. click it..
    Type in "Eas y" without the space in what you are searching for and then type in my name as the user. It's all there with teh tools needed etc etc etc. Enjoy
  6. #6 Re: Trans question, sitting for almost a year
    engines come out the top for sure.
  7. #7 Re: Trans question, sitting for almost a year
    Keller,TX
    So awesome, thanks guys.
  1. 4T80 Year specific question
    By SnowFlake in forum 1994-2011 4 speed Automatic (4T80E)
    Last Post: 08-19-2014, 10:10 AM
  2. Swapping Trans, year to year differences?
    By ColinWilson1980 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-08-2011, 12:41 PM
  3. trans sitting in 1st under full throttle
    By reem98 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-01-2011, 10:32 PM
  4. body year question
    By PLAYTME in forum General Tech Discussion
    Last Post: 10-30-2010, 10:55 PM
  5. what year trans?
    By SS98 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-28-2010, 02:11 AM
