Thread: Possible TCC RPM Problem
Results 1 to 4 of 4
  1. #1 Possible TCC RPM Problem
    Donating Users jacobmh27's Avatar
    Naugatuck CT
    On the Highway in very light throttle and right around 2000 RPM the Tach will jump a few hundred RPM. Just a touch more gas 2200 RPM no problems. Trans rebuilt about a year ago.
    http://www.cardomain.com/ride/3059486
    2001 GTP, TransGo shift kit, SSAC Headers, AeroForce Scan, TDC Racing FWI, Overkill PCM, 3.4 Pully,MSD Coil Packs, Moroso Wires, AL104's, 160Tstat
  2. #2 Re: Possible TCC RPM Problem
    Naugatuck CT
    Also my TSC Light and ABS Light is on I think that is the Right Front Sensor. If that could have anything to do with it
  3. #3 Re: Possible TCC RPM Problem
    Naugatuck CT
    Just checked my Codes on my scan Gauge
    P0620 Not sure what that is
    P1133 I get this sometime I think because of my O2 Simulator
    P1571 Traction control because I have the Light I guess
  4. #4 Re: Possible TCC RPM Problem
    First thing I would suggest is a good throttle body cleaning and plugs/wires if they are older. Very often this type of issue is tune up related.
    A quick google search
    P0620 Description Generator Performance
    1133 is your front O2, so it wouldn't have to do with the simulator for the rear O2
    1571
    http://www.gearchatter.com/viewtopic8503.php Likely a bad EBCM
    Seems like you have a few things to fix up.
  1. Need a direction to my GP's problem - FWD problem
    By isaac33 in forum General Grand Prix Discussion
    Last Post: 02-26-2013, 11:36 AM
  2. Is it a problem on my end? Picture Uploading Problem.
    By TJeno in forum Forum Bugs/Suggestions
    Last Post: 10-23-2012, 07:53 AM
  3. HUD Problem
    By WCF59 in forum Audio, Security & Visual Electronics
    Last Post: 09-23-2012, 01:37 AM
  4. Problem with transmission NO REVERSE...Any suggestions of problem
    By newmy1d in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-28-2012, 11:36 AM
  5. MAF problem?
    By bcantrell in forum General Tech Discussion
    Last Post: 05-24-2011, 08:57 PM
