Thread: Trans Dipstick with headers question
Results 1 to 7 of 7
  1. #1 Trans Dipstick with headers question
    SE Level Member gtpterp's Avatar
    Jul 2011
    MD
    Hey guys sorry if this is in the wrong section but I have a question about the trans dipstick and headers on an 00 GTP. I just put in ToG headers today and of course the dipstick won't go in easy without bending it...a lot. What is the best way around this? Just bending it (if so what about getting it secure with the bracket) or is there a dipstick I can get that will work with out modification. Thanks for the help in advance!
    -GTPTerp
    '00 GTP: TOG headers with high-flow Cat, Borla exhaust, 3.4 Pulley drop, 180* Tstat, NGK TR55
  2. #2 Re: Trans Dipstick with headers question
    They make one That's braided and can bend around easily
  3. #3 Re: Trans Dipstick with headers question
    SE Level Member JerzNick's Avatar
    Oct 2012
    New Jersey
    Getting around the trans dip stick is a pain in the arse! I unbolt the dipstick so it can wiggle a little bit, then remove TB and slide the down pipe right in.
    Bored block, Eagle Crank, XP Cam, Ported Heads/LIM/Blower/TB, 3.0 Pulley, CAI, Headers, 42.5#, AL 104's, etc...
  4. #4 Re: Trans Dipstick with headers question
    Jul 2011
    MD
    with that work with headers?
  5. #5 Re: Trans Dipstick with headers question
    SE Level Member Powertrike's Avatar
    Jul 2010
    MN, US
    Bending/spinning the stock dipstick housing really shouldn't be a problem as long as the tube is fully seating into the trans and the dipstick slides in/out ok obviously. Possible to tack on a simple mount for the tube somewhere?
  6. #6 Re: Trans Dipstick with headers question
    Togs require a specially bent tube or a lot of time bending it. You basically have to turn it into a pretzel to put them in.
  7. #7 Re: Trans Dipstick with headers question
    Oct 2012
    New Jersey
    works with my crappy pace setters...
  1. Where can I find a flexible trans dipstick?
    By PokerBlakeB in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-16-2012, 06:31 AM
  2. Dipstick question?
    By Silver GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-09-2010, 07:48 PM
  3. Trans dipstick question
    By theone2043 in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 12-17-2009, 01:38 AM
  4. Modified Trans Dipstick tube from Intense...
    By Iron Indian in forum Off Topic Discussion
    Last Post: 02-22-2008, 07:54 PM
