Thread: Still having shifting issues, really need help.
Results 1 to 18 of 18
  1. #1 Still having shifting issues, really need help.
    Mar 2015
    Lumberport, WV
    ok guys, I need some help here. I'm still having shifting issues. The last time I took it apart and put it back together It ran great for 2 days then started acting up like just like before. I will admit, I used a jug to save my old transmission fluidand when I pored it back in it was brown and runny.. I'm out of a job right now so I didn't have the money to buy new transmission fluid. The jug I used was brand new, new, never used. Not sure why it came out that color. I know that was bad for it but I've added about a quart of new transmission fluid plusabout a fifth of a quart of lucas transmission stabilizer. I've changed the solenoidtwice myself and have had it apart a total of times. Also I've been using Dex/mercinstead of Dex6 which I know is also bad. If I take it apart again, I will flush it and change the filter. If I reset the CEL it shift great for about 5 minuets. What should I do? Thanks for all the help in advance!
  2. #2 Re: Still having shifting issues, really need help.
    Mar 2014
    Tucson
    Which solenoid? What are the codes? Did you drop the pan and get a look at the magnet?
    Had a relative throw a couple solenoid codes in his car. Turns out the torque converter puked and sent crud through the whole thing... Causing the valves to stick.
  3. #3 Re: Still having shifting issues, really need help.
    Mar 2015
    Lumberport, WV
    I apologize for the lack of information in that post. It is the TCC solenoid. I've replaced it twice and still having the same code. I have also replaced all of the other solenoids, and I've never had the bottom pan off.
  4. #4 Re: Still having shifting issues, really need help.
    Mar 2014
    Tucson
    I'm sure other, more experienced people will chime in, but my initial thought are:
    1.) Wiring issue. Not likely, but I suppose it's possible there's a problem with the harness somewhere.
    2.) Dirty (contaminated) fluid causing the valve to stick. Not a problem with the solenoid.
    When you had the side cover off, did you happen to notice any black powder or goo sitting in the bottom of the case? Maybe looked a little like this:
  5. #5 Re: Still having shifting issues, really need help.
    Mar 2015
    Lumberport, WV
    Quote Originally Posted by BrandonHall10 View Post
    I didn't really pay attention, I just cleaned it up, However I vaguely remember thinking something inside the pan looked a little off, but I didn't put much thought into it? What If I did? lol
  6. #6 Re: Still having shifting issues, really need help.
    Apr 2015
    Columbus, OH
    I'm no tranny tech, that's for sure, but using the wrong fluid, dirty reused wrong fluid especially, certainly can't help. The oil is the life blood of the tranny. I would get new fluid in it before I went hunting tranny goblins. Did you at least strain the fluid before you put it back in?
    Top Swapped 01 Imp
  7. #7 Re: Still having shifting issues, really need help.
    Mar 2015
    Lumberport, WV
    Quote Originally Posted by bandook View Post
    ..no on the strain, sadly. I'm going to flush it and change the filter very soon. Possibly tomorrow. Just wondering how do you flush out all 13.4 quarts, sorry for the dumb question
  8. #8 Re: Still having shifting issues, really need help.
    Mar 2014
    Tucson
    Quote Originally Posted by scheuvront1993 View Post
    Here's a very well done write up about installing a shift kit. Covers everything you're after. Just skip the parts about the shift kit. (Unless you do that as well)
    http://www.grandprixforums.net/threa...ailed-Pictures
  9. #9 Re: Still having shifting issues, really need help.
    Mar 2014
    Tucson
    Sounds like something has contaminated your fluid. That's likely the cause of your reoccurring code. The solenoid was/is a symptom, not the root problem. What that is, I can't say. But what I do know from a recent tear down is:
    Black grit/sludge = cooked torque converter.
  10. #10 Re: Still having shifting issues, really need help.
    Mar 2015
    Lumberport, WV
    Hey there fellas, and possibly lady fellas. I haven't gotton around to changing the fluid yet sadly, however my problems have eased up slightly, the car isn't bucking as bad. I've noticed that if I clear the check engine light and get right on the interstate, my code stays cleared until I get back in stop and go traffic. I checked my fluid the other day and sadly it smelled burnt... I also wanted to get everyone's personal opinion. My car is a 2000 SE 3.1. Is it even worth putting money into? I'm not really afraid of the work and the engine in my car is great and car itself is in pretty decent shape.. compared to some of the others around here, pretty clean under the hood and underneath. The transmission is the worst of it but is it even worth trying to fix or possibly replace?
  11. #11 Re: Still having shifting issues, really need help.
    Nov 2011
    NY
    Have an 01' SE with over 220k on it (son drives it now), tranny rebuild around 120 from abuse, recent lim and front cover gasket job, still going strong! It all depends (worth), but rust is now its enemy! Engine puuurrrrrrrrs by the way!
    and as for your situation, you'd shoulda replaced that fluid as recommended... Only asking for trouble!
  12. #12 Re: Still having shifting issues, really need help.
    Mar 2015
    Lumberport, WV
    I appreciate the input, like I said my car is fair, the engine is in great shape with low miles. The body has a large dent on driver fender and couple other small dents, not much rust at all. there are a couple of spots on the rockers that need some attended too but not bad. The interior is great other than the lip on the dash is warped.. right about the instrument panel, does anyone know how to fix that? also I have the problem with the passenger floorboard, being wet. But I know how to fix that.
  13. #13 Re: Still having shifting issues, really need help.
    Mar 2015
    Lumberport, WV
    Alright everyone, today I finally drained the fluid and swapped out the filter. So far no check engine lights or anything but I have not extensively tested it yet. Probably get around to that tomorrow. my pan was NASTY. The black sludge was god awful. The car recently had the filter changed before I got it and the mating surfaces were spotless, and the guy I got it from told me he just changed it when I bought it. That being said I'm assuming it has been changed in the last 6 months or so. So I'm assuming the amount of nasty build up I had is even worse since it has accumulated over only the last 6 months or so. The magnet was horrible, there was at very least 1/8 of an inch build up on the magnet. I wish I had taken a picture. It was terrible, lol. Also when I drained the fluid out of my catch pan, it was absolutly black... Blacker than my oil..
  14. #14 Re: Still having shifting issues, really need help.
    Mar 2014
    Tucson
    Really curious to see what the long term it's on this.
  15. #15 Re: Still having shifting issues, really need help.
    Mar 2015
    Lumberport, WV
    Also Brandon Hall, the picture you posted in the beginning of this thread... that's exactly what my transmission pan looked like.. but ALOT worse.
  16. #16 Re: Still having shifting issues, really need help.
    Mar 2015
    Lumberport, WV
    Well I drove the car to town and back today(I live 8 miles outside of town.. I literally live in the woods). At first it was fantastic, improved throttle response, absolutely no bucking. It shifted fantastic, ran just like it should... well that only lasted for about 3 miles, then the CEL came back on and even still it didn't do bad. I made a couple of stops in town and eventually the light went off for about 10 minuets and it shifted great again. On my way back home my CEL popped back up and I decided to take the car to my local NAPA but it's the smallest NAPA in the world.. it is literally the size of my living room, and they did not do the CEL check. I was avoiding my local Advance today.. lol. Anyhow it stayed on all the way home and gradually it got slightly worse. It is however still a lot better than it was before.. but still not fixed.. I'm probably just gonna milk it until I can afford to buy a new transmission.. or learn to rebuild this one, lol.
  17. #17 Re: Still having shifting issues, really need help.
    I may have missed it.. which codes are you getting?
  18. #18 Re: Still having shifting issues, really need help.
    Mar 2015
    Lumberport, WV
    I'm not sure of the exact code, but it is the TCC solenoid Stuck on/open... or something like that. Let me explain a little better about my problem. At take off the car does great and If I don't let off it will shift through all gears. If i'm going through town in second gear I have issues.. It's like the car doesn't want to take throttle. I keep giving it more and more gas and nothing happens. I have to stomp on it for it to really get moving in second. All other gears seem to work fine.
  1. Shifting issues...
    By mick777wauchope in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-21-2012, 10:19 PM
  2. shifting issues
    By caruthers in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 06-14-2012, 07:35 PM
  3. Issues shifting into 3rd/4th
    By Powertrike in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-20-2010, 12:32 AM
  4. shifting issues '97 GT
    By m1sterb0b in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-15-2010, 04:12 PM
  5. Shifting issues in 96 GP with 3.1
    By girthman49 in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 11-02-2009, 10:41 AM
