Thread: Turn Up Line Pressure or Shift Kit???
Page 1 of 3 123 LastLast
Results 1 to 20 of 55
  1. #1 Turn Up Line Pressure or Shift Kit???
    Apr 2015
    United States
    My 2006 Grand Prix GXP with 119,000 miles has since I've owned it has had an occasional delayed engagement (taking off from a stop and banging into gear after revving) and sloppy shift problem (sometimes it'll shift painfully slowly). These problems are so intermittent. Some days the transmission shifts good and runs great and then other days it's just not feeling it. I don't think this transmission needs rebuilt yet, as it has its days where its a beast and when I changed the fluid I didn't find any signs of excessive wear.
    I've read online and found two things that people do that usually solve these issues. I would like to know which is the better route to help solve these issues:
    1. Crank line pressure up some via tuning
    or
    2. Install a shift kit.
    Which one should I take on and that you think would help solve some of these occasional issues?
    Shift kit's definitely cheaper hhaa
  2. #2 Re: Turn Up Line Pressure or Shift Kit???
    Feb 2013
    Missouri
    Both. and a cooler.
  3. #3 Re: Turn Up Line Pressure or Shift Kit???
    Apr 2015
    United States
    Right now I only have the resources and time to mess with one or the other. Which one will make the biggest difference? And if I should do a shift kit, which shift kit do you recommend to help solve this?
  4. #4 Re: Turn Up Line Pressure or Shift Kit???
    Feb 2013
    Missouri
    Transgo shift kit, and a bottle of Lubeguard Red. Then goto the JY and pick up a transmission cooler from a Explorer. They're more than enough to cool our transmissions (within reason), have mounting ears, and are pretty cheap. Make sure to clean it out. Ebay has the shift kit for about $40, so it'll help in the wallet department.
  5. #5 Re: Turn Up Line Pressure or Shift Kit???
    Apr 2015
    United States
    If it is a shift kit I should go with, I'm leaning towards doing a ZZP kit, because I like that you can select shift firmness (I would probably be going with the hardest setting ). I've heard good things about TransGo, but I'm not sure if that kit would help alleviate these issues, since I heard its not a whole lot over stock.
  6. #6 Re: Turn Up Line Pressure or Shift Kit???
    Feb 2013
    Missouri
    Zzp is the worst shift kit available. If you want a selectable firmness type thing, I hear good things about Intense. Transgo really is the best though.
    There's always the DIY route where you order spacers from McMaster and put the in. The ZZP kit is just plastic spacers and you just put in a longer spacer for firmer shifts. Transgo has an entirely new spring set to put in. If Transgo doesn't fix your problem, no shift kit will.
  7. #7 Re: Turn Up Line Pressure or Shift Kit???
    Apr 2015
    United States
    Will the TransGo help with the issues I'm having? I read somewhere that it's almost just a stock replacement. And I've heard reallllyy bad things about Intense screwing over people.
  8. #8 Re: Turn Up Line Pressure or Shift Kit???
    Dec 2012
    Where 4T65E's were born
    Stock GT/GTP if it matters
    Transgo
    A shift kit will help the slow shifts, but not the bump start. Higher line pressure would cover that problem up for a while.
    Sold.
  9. #9 Re: Turn Up Line Pressure or Shift Kit???
    Feb 2013
    Missouri
    I edited my previous post...Transgo is nowhere near a stock replacement.
  10. #10 Re: Turn Up Line Pressure or Shift Kit???
    Apr 2015
    United States
    I'm thinking I'll go with the tune then and do higher line pressure. I know that when driving in TAPShift mode, line pressure is increased - and when driving in TAPShift mode, I almost never have shifting problems. This is why I usually drive in TAPShift and why I think increasing line pressure would actually help.
  11. #11 Re: Turn Up Line Pressure or Shift Kit???
    Feb 2013
    Missouri
    It'll be a band-aid fix. The transmission itself needs work. Might just be a fluid flush (which you have to do when you install a shift kit), or it could be something a bit more involved.
  12. #12 Re: Turn Up Line Pressure or Shift Kit???
    Apr 2015
    United States
    Would the Diablosport tuner increase line pressure enough? Or would I have to step up to something more steep (and much more expensive) like an HP Tuners?
  13. #13 Re: Turn Up Line Pressure or Shift Kit???
    Apr 2015
    United States
    Quote Originally Posted by Booba5185 View Post
    I changed the fluid already, didn't help and didn't hurt. I also got rid of the fridge magnet and installed the upgraded magnet and another upgraded magnet on the filter.
  14. #14 Re: Turn Up Line Pressure or Shift Kit???
    Feb 2013
    Missouri
    You'll want an actual tune, not a POS OBD2 port wannabe. HPT gives you the ability to tune. I'd contact Overkill for a tune, or maybe wait a week or 2, since Reptile is "researching" 04+ tunes. Reptile is a member of the site and has fantastic tunes, I have one on my 2000, but he doesn't do 04+'s yet.
    What temperature is your transmission running at?
  15. #15 Re: Turn Up Line Pressure or Shift Kit???
    Apr 2015
    United States
    It rarely runs over 204*F and its rare to see it above 200*F. Usually around 150-195*F.
  16. #16 Re: Turn Up Line Pressure or Shift Kit???
    Feb 2013
    Missouri
    195*F is okay, but I'm not comfortable with mine running that hot. 175*F is the max "optimal" temperature. That's not your problem though.
  17. #17 Re: Turn Up Line Pressure or Shift Kit???
    Apr 2015
    United States
    Any idea what causes these issues? Bad PCS? This seems to be an extremely common problem with these trannys.
  18. #18 Re: Turn Up Line Pressure or Shift Kit???
    Apr 2015
    United States
    It mainly reaches those higher temps when sitting in traffic or on hot days... like today.
  19. #19 Re: Turn Up Line Pressure or Shift Kit???
    Feb 2013
    Missouri
    It can be the PCS, among other things. Do you have any means to pull codes? With transmission codes you have to pull codes when the problem happens (or at least don't shut the car off before reading codes).
  20. #20 Re: Turn Up Line Pressure or Shift Kit???
    Feb 2013
    Missouri
    It's possible it's your forward apply band, too. When you put it in manual 1st it applies another band, and that's why it doesn't slip. I'm not 100% sure that Tap Shift applies that manual 1st band, but I think it does.
  1. how to replace PS pressure line
    By nastypvp in forum General Tech Discussion
    Last Post: 02-23-2015, 01:22 AM
  2. Fuel line pressure
    By gtpsgofast in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-15-2013, 08:01 PM
  3. Help with Line pressure setting
    By OrangeL67 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-28-2011, 06:57 PM
  4. A/C low pressure line location on 98 GTP
    By Juanmiguel in forum General Tech Discussion
    Last Post: 02-26-2010, 10:02 PM
  5. Pressure Supply Fuel Line
    By GreenNirvana101 in forum General Tech Discussion
    Last Post: 03-26-2008, 10:08 PM
