I don't have a scanner that can read those and the shops around here charge a pretty penny ($100) to do this. What I find odd is that some days this transmission shifts strong and then other days it doesn't with no rhyme or reason.
As far as I know, any scanner will read them, they are P codes, just like the engine. It's the C codes that won't be recognized. Have you tried resetting TAPS? Disconnect the battery overnight.
I've read that too, does increased line pressure assist with this? I know its not a permanent fix. But if I can get more time out of this tranny before rebuilding it that would be great.
Woulnd't P codes throw a check engine light? I have no lights.
All of those codes say stored in the memory, so wouldn't I technically be able to hook up my scanner at any time to grab those codes?
I guess I'll see if I can save up and get a hold of an HP Tuners and crank the line pressure up. I guess till then I'll drive in TAPShift to save the cluthes lol.
Don't I have to send in my PCM for that? I can't do that, as this is my DD.
There'd be a core charge, but you can ship your stock one back after you get the tuned PCM. IF Reptile starts doing it, then he'd probably just send you a PCM tuned and you keep your old one. I'm not speaking for him or anything, that's just how he handles the 98-02 stuff.
Overkilled? Good place to order a tuned PCM from? If not from Reptile.
Overkill. Yes, I've heard nothing but fantastic things about Will.
http://getoverkilled.ca/
Will I have to do the crank sensor relearn?
Technically yes, but it normally doesn't impact how the car runs all that much. It mainly smooths out the idle. I've had my tune for months and I'm still waiting on my friend to let me use his scan tool to do a learn, lol.
Alright thanks for all the help. Any idea if the Overkilled tune bumps up line pressure enough to help out my tranny?
