I spent about $2 on a piece of steel pipe for mine.![]()
Intense is by far the best. Thrasher was even better when available. ZZP you can build it for pennys (local hardware BS) if interested I got a parts list for the zzp kit. I have never heard of any issues with the zzp setup but if you build your own you can use copper/brass stuff
Some of the transgo kits say without tap shift. I can't find one that says w/ tap shift.i will probaby just try the zzp kit.
I don't see anything on the transgo website that says tapshift is an issue..
http://www.transgo.com/products.php?...product_id=222
It's basically the same thing as ZZP except it uses metal instead of plastic and comes with springs so I don't see how it would be an issue.
K awesome.
