The passenger side cv axle is going to need to be replaced.
I have two questions:
1. Should get a new or used replacement? I have read that the new ones generally last a year or so. So I'm wondering if a used one will last longer provided the used one doesn't have a ton of miles on it.
2. I know that some trans fluid will leak out when replacing the cv axle, with 244,xxx miles on the car should I do a pan drop/filter change/top off or just top off the fluid and leave it alone? The fluid is a darker red. It seems to be shifting a little funny but I don't know if it's really doing it or if I'm just paranoid. Either way how much trans fluid will I need?
Thanks I advance.
