Thread: trans swap question
Results 1 to 9 of 9
  1. #1 trans swap question
    Jul 2012
    KCMO
    I have a 98 gtp and i am sure the trans is on borrowed time i was at a picknpull and there was an 03 bonnie that was supercharged it had a gm reman in it and the rear of the car had been hammered so i think it was there due to a wreck not mech. Failure . So will it swap out or not.
  2. #2 Re: trans swap question
    Dec 2012
    Where 4T65E's were born
    It's a different transmission. The valve body and electronics are different, as well as the final drive ratio. In order to use it I believe the channel plate and differential would need to be swapped.
    Sold.
  3. #3 Re: trans swap question
    Yeah.. 03 is the pink spotted unicorn year. Bonne SSEi would work if it were 00-02
  4. #4 Re: trans swap question
    hangover park IL
    at most you would have to swap out the differential, bolt on your older style external range switch and move a few pins on the trans connector
    ~James~ Psychotic Gearhead
  5. #5 Re: trans swap question
    Dec 2012
    But 03 was the first year of the newer style pcs right?
    Sold.
  6. #6 Re: trans swap question
    GT Level Member Shiftingshaddow's Avatar
    KC
    since you have to pull the tranny out anyway to swap them, why not just take a stab at rebuilding your own yourself?....that is if you were going to do the swap yourself.
    i did a swap once putting a 2000 with 106k into the one with 180k. the 106 lasted only a few months and that was from a car where the history was known.
    point is, you're not going to know what you are getting--even if you know the car's history (which you won't from pick in pull). these things pretty much are guaranteed to break. its kind of a hassle finding the right transmission for the right years, etc. and once you do all the work putting it in (which from the top with a cherry picker is not terribly difficult) you are basically just a) hoping you got one with a good rebuild already or b) just hoping for as much time as you can get before the replacement.
    but rebuilding it yourself.....that is something i want to try if there is a next time. you get to learn a bunch of stuff doing it yourself.
    2001 GTP Special Edition
    ZZP DP with Cat, Open Cone Intake, ZZP 1.0 PCM, 3.4 pulley, AL 104s, Rocker Panel Delete.....
  7. #7 Re: trans swap question
    Dec 2012
    Well what he didn't mention was what's wrong with the one in it now and how many miles is on it. Could be something common or possibly something rebuild worthy.
    Sold.
  8. #8 Re: trans swap question
    Dec 2012
    troll land
    Also 98 has a dif cool line than 99+
  9. #9 Re: trans swap question
    Jul 2012
    KCMO
    The trans is slipping in 1 and 2 under boost and 4th is out it feels like the torque convertor locks up but you give it throttle and it downs shifts to 3rd I was reading about the repining would that work on an 03 out of a bonnie or not is that only for the 03 regal / gtp trans. After I get some time I would like to go through the trans I have I just need to get a trans and put it in so I can drive it. The car is my daily . and as far as on barrowed time it was working ok till I installed a new fuel pump and it started putting full power to the ground two weeks ago this last week it started having these issues. As far as the lines are concerned could I just swap them off the newer car to mine or just use the fittings.
  1. Trans Connector/trans swap... Pulling side cover? 01 GT
    By MrPhotographer06 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-27-2013, 01:34 AM
  2. Comp G trans swap Question
    By dbcruzr in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-05-2013, 11:27 PM
  3. Trans swap question
    By fleck24 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-03-2012, 08:24 AM
  4. Trans Swap Cost Question
    By ljmonnin12 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-12-2012, 05:53 AM
  5. Trans swap ???
    By cogsracing in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-28-2011, 12:40 PM
