Thread: VSS replacement still throws P0502 and P0503
Results 1 to 7 of 7
  1. #1 VSS replacement still throws P0502 and P0503
    Jun 2012
    St. Paul, Minnesota
    Well guys and gals, what am I looking at now? I was experiencing hard shifts and the speedometer dropping and then popping back up while driving. This happened at all speeds. I checked my Aeroforce for the codes and it was showing P0502 and P0503. Those are both related to the VSS. I spent the 20 dollars and replaced that but upon the next drive it threw the P0502 again and is shifting hard and the speedometer is jumping around still.
    What is the next thing that needs to be checked? I have some ideas but I came to the experts before I waste my time.
    Thanks in advance.
    Info on the car is 2001 GTP 120k
  2. #2 Re: VSS replacement still throws P0502 and P0503
    Check the whole wire harness to it.
  3. #3 Re: VSS replacement still throws P0502 and P0503
    Enfield, CT
    ^^^^ this
  4. #4 Re: VSS replacement still throws P0502 and P0503
    Jun 2012
    St. Paul, Minnesota
    Well I found the breaks in the wires. They were right up by the PCM? (the one that is in the air box) any ways, I need to know if I can cut out the section of wire that is down to one strand of copper holding it together and put in a butt splice? The wire is for pin 61, and if AutoZone's pin identification is correct, it is the throttle Position Sensor ground.
    The picture is kind of blurry but it shows what I am dealing with. There are a couple other wires that have some of the jacket scrapped off of them. I am planning on wrapping each wire individually with electrical tape and calling it a day.
  5. #5 Re: VSS replacement still throws P0502 and P0503
    heres a how to i posted some time ago, how to solder.
    cut those wires back and re connect them or add new wire if need be. soldering kit will cost you like 15 bucks. use shrink tubes. flux core solder.
    http://www.grandprixforums.net/threa...ail-replacment
  6. #6 Re: VSS replacement still throws P0502 and P0503
    Jun 2012
    St. Paul, Minnesota
    Not the best solder job, but it'll do. No more codes and everything is back to normal.
    Thanks, guys!
  7. #7 Re: VSS replacement still throws P0502 and P0503
    as long as you used the shrink tubes over it, it should be fine.
  1. Code P0502 and P0503
    By 40th GP in forum General Tech Discussion
    Last Post: 08-22-2014, 09:57 AM
  2. Timing Chain/Belt replacement? Tension-er replacement?
    By void33 in forum General Tech Discussion
    Last Post: 02-21-2014, 02:34 PM
  3. Autostart throws codes
    By Schrupps in forum General Grand Prix Discussion
    Last Post: 02-05-2014, 02:32 PM
  4. Car dies randomly and throws codes P0601 P0606 U0107
    By rybannez in forum Introductions/Noob Questions
    Last Post: 08-18-2013, 11:04 AM
