Thread: Trans swap question
Results 1 to 3 of 3
  1. #1 Trans swap question
    Merrillville, IN
    The trans in my 02 GTP is toast. I have access to an 03 GTP transmission
    with very low miles on it. Will a trans from an 03 GTP work in my 02 GTP?
    I have not been able to figure out if there is any difference yet searching
    on line. It appears it is okay, buy looking for help from anyone that knows
    better. Thanks
  2. #2 Re: Trans swap question
    Won't work.
    Valve Body is different.
    I assume you could swap valve body's and the channel plate from the '02 trans to the '03...
  3. #3 Re: Trans swap question
    Correct amundo
  1. trans swap
    By STW in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-02-2012, 09:22 PM
  2. Trans Swap Cost Question
    By ljmonnin12 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-12-2012, 05:53 AM
  3. Trans Swap
    By Terry102 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-25-2011, 08:38 PM
  4. trans swap
    By GOINDEF in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-03-2011, 01:13 PM
  5. Trans/PCM swap
    Last Post: 10-06-2009, 09:13 PM
