Quote Originally Posted by GTP131 View Post
Hey Dadillac. You are in luck, I just did this fluid change again today, so it's still fresh in my head.
1. No, there is no drain plug on the factory pan. You can reduce the mess, however, by removing the 7 or so bolts closest to the rear of the car, then slowly loosening all the other bolts. It will make all of the fluid run out the same side, making it easier to catch the fluid. There are some people on the forum who pump some of the fluid out through the dipstick as well.
2. It should take 7.5 qts of fluid. I recommend using Dexron VI, which you can get at Wal-Mart for about $4.50 a qt.
3. Yes, the factory pan gasket is reusable, if it is still in good shape. You are probably doing the trans filter at the same time, which should come with a gasket you can use if your factory gasket is busted or something.
I wasn't asking if the pan had a drain bolt. On the 4T80e, once the pan is dropped, there is a drain plug inside the trans that needs to be removed. The 4T80e is a dry sump set up. All of the fluid, with the exception of a quart or two, is held in the side cover. My question was directed to a similar plug. But tour answer pretty much tells me that the 4t65 holds its fluid in the pan. Thanks for the reply it is very helpful
Don
