Thread: Trans fluid change question
Results 1 to 5 of 5
  1. #1 Re: Trans fluid change question
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Hey Dadillac. You are in luck, I just did this fluid change again today, so it's still fresh in my head.
    1. No, there is no drain plug on the factory pan. You can reduce the mess, however, by removing the 7 or so bolts closest to the rear of the car, then slowly loosening all the other bolts. It will make all of the fluid run out the same side, making it easier to catch the fluid. There are some people on the forum who pump some of the fluid out through the dipstick as well.
    2. It should take 7.5 qts of fluid. I recommend using Dexron VI, which you can get at Wal-Mart for about $4.50 a qt.
    3. Yes, the factory pan gasket is reusable, if it is still in good shape. You are probably doing the trans filter at the same time, which should come with a gasket you can use if your factory gasket is busted or something.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  2. #2 Re: Trans fluid change question
    Feb 2013
    Woodbridge NJ
    Quote Originally Posted by GTP131 View Post
    I wasn't asking if the pan had a drain bolt. On the 4T80e, once the pan is dropped, there is a drain plug inside the trans that needs to be removed. The 4T80e is a dry sump set up. All of the fluid, with the exception of a quart or two, is held in the side cover. My question was directed to a similar plug. But tour answer pretty much tells me that the 4t65 holds its fluid in the pan. Thanks for the reply it is very helpful
    Don
    2004 GT1
  1. Tools/Materials needed for trans fluid change and filter change
    By JDrach in forum General Grand Prix Discussion
    Last Post: 12-10-2012, 07:47 AM
  2. Transmission Fluid - 173K..To change or not to change, that is the question
    By 99XC600 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-01-2012, 10:03 PM
  3. To change trans fluid or not?
    By Elite6 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-11-2011, 10:08 AM
  4. How much Fluid for Trans Filter Change
    By dhdolphns in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-06-2011, 03:48 PM
  5. 01 gtp Trans fluid change
    By Draco in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-06-2011, 07:38 PM
