Thread: HELP..... Solenoid replacement
Results 1 to 15 of 15
  1. #1 HELP..... Solenoid replacement
    Nov 2013
    lville
    So i have a bad transmission pressure solenoid....since i am doing one i might as well make sure the other one is new. I can not figure out where they are hiding.... I know that sounds dumb but everything on the tranny does not look like the new ones. I have found a large wire plug on the top of the tranny next to the air box and another under the car near the passenger side. I cant figure out how to get the top plug off with out breaking it and the one under the car is hard to get to but i know i can once the car cools down and i stop burning my hands trying to get it out to figure out if it the correct one. any suggestions will help.
    thanks
  2. #2 Re: HELP..... Solenoid replacement
    you mean the shift solenoid? if so its in the tranny pan. easy to change.
    if you mean the tps or tcc solenoids your talking a much larger job being you need to take the side cover off the tranny and go inside a bit to get to them.
  3. #3 Re: HELP..... Solenoid replacement
    Nov 2013
    lville
    Yeah what im looking for is inside the side case.... how hard is this to do?
  4. #4 Re: HELP..... Solenoid replacement
    Nov 2013
    lville
    is the write up on this site? I have been searching all afternoon... Hard like i need to remove the tranny? It almost looks like if i remove the mount and a couple other thing i should be able to get the cover off. Does that sound right or do i need more room?
  5. #5 Re: HELP..... Solenoid replacement
    oh that roundish looking plug you squeeze the sides and then pull it off.
  6. #6 Re: HELP..... Solenoid replacement
    Nov 2013
    lville
    Thanks!
    So my pops used to have the same car are you and that is what got me into the 3800sc motor! I will keep you updated on this one! I did get the hub replaced this week! I cant believe that it went out that quick and with very little warning..... I could feel the movement in the bearing once i had it out of the car.... I replace both front hubs maybe 4 years ago....
    I have a bet going with a couple friends that my car can last me another 5 years! I bet a few friends that this car can last me another 5 years! If i can win (i will do anything in my power to win) i will get 4k if i an get them to pay up!!!
  7. #7 Re: HELP..... Solenoid replacement
    Enfield, CT
    There is a write up with pics somewhere. I've done it a long ass time ago. It's kinda hard to do and IIRC the servo gasket can only be found at the dealer
  8. #8 Re: HELP..... Solenoid replacement
    Nov 2013
    lville
    Dude i think i need to start paying you for all the advise!!! Do you know if it is possible to remove the cover without pulling the tranny out, just to replace the solenoids? it really seems like if i remove the mount that it will give me the room?
  9. #9 Re: HELP..... Solenoid replacement
    http://www.grandprixforums.net/threa...e-cover-access
    pretty sure th e2 nd pic posted, if you follow the harness to its 2 ends those are what your after.
  10. #10 Re: HELP..... Solenoid replacement
    that how to is for the 4 th hub and its written to be done in the car. re read slowly and picture the trans in the car still.
    bill likes to take things out for better pics. it does not need to be removed.
    that harness also likes to break so be careful with it, and check it over for damage, its been the cause of the code the past, not the solenoids. (the one inside the side cover)
  11. #11 Re: HELP..... Solenoid replacement
    Enfield, CT
    yea my connector is what was broken. total BS
  12. #12 Re: HELP..... Solenoid replacement
    3800 runs forever aslong as you change the oil. good luck. you may just win that bet.
  13. #13 Re: HELP..... Solenoid replacement
    Nov 2013
    lville
    Is it easy to tell if the connector or harness is broke? Im planning on doing this tomorrow but i will not have another car to get to the parts store till late in the day.... Do i need a new gasket or any other items to complete this job? My wife might be getting a new job soon and this will require me to drive my car (hers gets towed behind the truck) across the country.... the prix has put in her time in LA traffic for 90k miles and hope it can make the trip from the Ohio valley back to the west coast!
  14. #14 Re: HELP..... Solenoid replacement
    you could test it with a multimeter, or just look for cracks or breaks. that harness see a lot of heat, so they get brittle.
    gaskets not sure. im sure theres one tho.
  15. #15 Re: HELP..... Solenoid replacement
    All soleniods are inside the side cover. I took those pics at the time someone asked about the job. I happened to be swapping a trans and camming the car at the same time. Hence.. out of the car. There's always parts laying around to take pics of..
    Side cover removal isn't a fun job, doesn't have to be a bad job either though.
  1. Pressure Control Solenoid(EPC), TCC, 4th Clutch Hub Replacement in the Vehicle.
    By 02NavyBlue in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-09-2013, 12:47 PM
  2. 1-2 Shift Solenoid Replacement
    By TeeWX in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-18-2011, 02:52 PM
  3. 2001 grand prix solenoid replacement question
    By 01whitegp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-25-2011, 11:44 PM
  4. not goin into gear after solenoid replacement
    By jamesy011 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-26-2010, 02:20 PM
  5. Trans pressure control solenoid replacement
    By PrixGT in forum General Tech Discussion
    Last Post: 07-06-2010, 09:21 AM
