Thread: Rebuilding Trans Question
Results 1 to 2 of 2
  1. #1 Rebuilding Trans Question
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    So my tranny in my 01 GT has 4th gear out and the fluid is very brown/black. It shifts fine but i want 4th and I know its not gonna last forever with the crap fluid and i dont wanna change it and risk it starting to slip.
    I want to get an HD tranny from the junkyard and rebuild it. So my first question is what cars to avoid and are there any years that have bad bad parts? Obviously I want the one with the lowest miles I can find so the hard parts are less worn. Probably out of a buick if i can find one. Normally buick owners are nice to thier cars. Lol
    Next question is what special tools i will need?
    I know i'll need a clutch compressor, a seal puller, and caliper to measure parts
    Do I need a special tool to pull the clutch housings out of the tranny case?
    Thanks for any help.
    NOTE: I Know i will have to have a tune done for the gear change going from the 3.29's to 2.93's. The reason I am going with an HD tranny is for the gear ratio. As long as i'm going to swap my tranny i may as well get a gear ratio that will give me better mileage as my car is a DD and not a racecar.
    I went NA when a whore left -$300 in my bank account.
  2. #2 Re: Rebuilding Trans Question
    GT Level Member primem's Avatar
    Sep 2013
    Calgary, Alberta
    Trans rebuilding is pretty technical. If your sure you want to attempt this go to autorepairmanuals.biz and buy a rebuild manual written by the automatic transmission rebuilders association for this specific tranny. It will show you step by step what to do and what special tools you need.
    2004 comp g
  1. Trans question!
    By CyxRyan in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-09-2013, 08:14 PM
  2. which gasket set? and question about rebuilding
    By Spartanzz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-07-2012, 05:24 PM
  3. bad trans is it worth rebuilding?
    By Naturallyhammered in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-02-2010, 07:28 AM
  4. Trans question(s)
    By grmchne78 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-21-2010, 01:09 PM
  5. Trans question
    By davidl25 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-04-2009, 07:27 PM
