ok i recently picked up a 98 GTP engine and i am going to rebuild it to put into my fiero. I am trying ot figure out what engine gasket set i should buy. All the gaskets from ZZP (the cheapest option) or the victor reinz gaskets set from rockauto.com? Also i herd someone say that you can remove that balance shaft? Do you have to run a double roller chain is order to remove that? And then anyone have anything they would recommend i should do to the engine while i am rebuilding it?
