Thread: Dark trans fluid
Results 1 to 11 of 11
  1. #1 Dark trans fluid
    Jul 2011
    Baltimore, MD
    My 00 GT has been seeing the temps rise faster than usual. I just came back from Jersey for my uncle's funeral and coming back down the turnpike i was staying in the 200-210 range.
    Doesnt help that i lost OD not too long ago and I get the p0742 and 1811 when im cruising around and the trans gets hot. I'm thinking this week about throwing on a trans cooler/shift kit and doing a flush and full. Just checked my fluid on my lunch break and it was pretty dark. Is it a lost cause or worth a shot?
    My ultimate plan is to wait till my motor build begins to start building the trans, so im tryina baby this thing till next summer...help
  2. #2 Re: Dark trans fluid
    Dec 2012
    Where 4T65E's were born
    Well I'm going to guess that you have quite a few miles on that, at least in the 160-180k range?
    P0742 is the torque converter clutch stuck on code. That's usually the fault of a $17 solenoid (TCC solenoid), and is accessible from the side cover. Which of course requires dropping one side of the subframe, not hard but requires a good amount of tools and time. That will probably have to get fixed, it's not going to get better.
    P1811 is usually the fault of another solenoid, the PCS. This can be covered up with a shift kit, but seeing as the TCC solenoid needs replacing, you'll probably just do them both, if at all.
    And loosing overdrive is the result of the 4th clutch hub failing. That takes a little more work to get into the trans, but as an average DIY'er like myself, I just replaced those 3 things in my trans not too long ago on my own.
    Also those temps are not abnormal, have you checked the coolant level? What was the ambient temp outside at the time?
    So at this point a shift kit and fluid filter with lucas trans stop slip may help only with P1811, but seeing as the fluid is dark that makes it iffy. How dark are we talking? And do NOT flush it, that's probably a 90% chance of killing it, especially at this point.
    Do you have tools to do things like dropping a subframe a foot? It takes 2 jacks and jack stands, 33 or 36 mm socket, socket set from 13-19mm, torx bits up to T40 etc. Overall it depends on if it's worth it to you to put the time and money into it, and of course the risks of it failing from something else soon.
    Sold.
  3. #3 Re: Dark trans fluid
    Jul 2011
    Baltimore, MD
    Coolant level is good, checked that yesterday. Temperature outside is averaging 55* lows in the 30's at night. The fluid looks like liquid ash is how i described it to a co-worker. So, your saying to not do the filter and fluid tomorrow? I just need it to last out until i put the motor together. My 03 should be out the shop tuesday from the motor swap (L67), but i still like to have the use of the 00 while i work out the kinks and get my tags straightened out.
    I got some buddies that could help me with the 4th hub and solenooid replacement, but they would rather see me swap in a HD trans and call it a day. I just dont want to have my daily down for a considerable amount of time.
  4. #4 Re: Dark trans fluid
    Dec 2012
    Well swapping an hd trans is going to require some changes to be made in the pcm's programming as the gear ratios are different. The HD's aren't all that much different either.
    For 55 degrees outside, 210 does seem a little higher than what these usually run at in those temps. It could need a new thermostat or maybe a flush if the coolant is gunky. Assuming it's reading the temp correctly.
    And the trans fluid looks like what?? Liquid ash? So you're saying that there are literally metal flakes in the fluid? Even just a pan drop at that point may kill it, though it would seem it's already on its last leg if thats the case. See if you can post a picture of the fluid on the dipstick with this ash.
    Sold.
  5. #5 Re: Dark trans fluid
    GTX Level Member Bakerdd's Avatar
    Raleigh, NC
    I just had the p0742 code pop up on my car. I don't have the second code you have but my fluid was pretty dark also, sort of like the color of dr pepper or something. I just did fluid/filter change plus the stop slip and it didn't help anything. From what I've read up on my code, there are other problems causing the solenoid to get stuck and my trans has been sucking for some time now so I knew it was going to crap out sooner than later. I've just opted to do a rebuild at this point since I'm kind of figuring a new solenoid is just a temporary fix if other stuff is going on. Plus you have the other code and issues on top of the problems I'm having, it doesn't sound too good man. And sorry if all of this is a little vague, transmissions are not something I know much about. This is just pretty much a summary of what I've been reading on here
  6. #6 Re: Dark trans fluid
    A trans swap or soleniod replacement/4th hub is probably going to take a first timer about the same amount of time.
    On the HD trans.... it's the same trans except for the larger differential and shorter axle as the non HD, beyond gear ratio. And that gear ratio is because of the drive/driven gear tooth count. Otherwise, the clutches and nearly every other part is identical between the HD and non HD.
    Being a GP you should have a 3.29 overall gear ratio IIRC. You could get another non-hd and a diff/diff cover from an HD with the shorter axle and not have to change programming. Then you'd have the benefits of the HD, a lower cost (if you go JY) unit and be all set.
  7. #7 Re: Dark trans fluid
    Jul 2011
    Baltimore, MD
    On the way to work today, everything seemed normal, although it is like 30* outside this morning. I went and picked up the Hayden 404 and a new filter
    I'll probably grab the fluid from wal-mart when i get off. I dont plan to flush it, but now that i seen how bad off the fluid looks, i feel i should at least get
    something to replace and throw in a container of lucas. Im trying to find the shift kit pieces i let them loose in my tool bag, so im attempting to empty it
    and retrieve them.
    With the cooler, i'll probably try and run it separate from the internal cooler in the radiator. Anything to look out for? and when i clip the rubber portion
    of the trans lines what size fitting would fit in there as i know the lines coming off the cooler are 3/8
  8. #8 Re: Dark trans fluid
    Dec 2012
    Defiantly use lucas if it looks like that, exchange it from a quart. The fluid to buy from walmart is probably the valvoline max life fluid, they're in gallon jugs so you don't have to buy a million. 2 should be good, it will be for sure if you're using a quart of lucas.
    The hoses slip right over the stock lines for the cooler. It's highly recommended to flare those lines before pushing the hose over it, so there's something for the clamp to grip onto and it doesnt get forced off with pressure. I did a half-flare since a full would have been tricky to get the hose over.
    Sold.
  9. #9 Re: Dark trans fluid
    Like 02, when I've done it, I like to not flare it as much as him...but bubble the end of the line with a flare kit. Similar to what he did, just stopping once the line starts to bubble outward. Then use two fuel injection hose clamps per connection point to quadruple insure yourself based on the pressure running through the lines.
  10. #10 Re: Dark trans fluid
    Arizona
    I use some sticky tacky rtv around the pipe and slide the over it typically 1-2inches an use the same clamp u do. I like the extra insurance
  11. #11 Re: Dark trans fluid
    I end up working on it again down the road. In that case.. RTV makes the job much tougher to take apart/do again.
  1. Dark Green Power Steering Fluid
    By scross in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-10-2013, 12:36 PM
  2. Trans fluid help!
    By CyxRyan in forum General Grand Prix Discussion
    Last Post: 08-29-2013, 12:17 PM
  3. Just flushed brake fluid, and now dark again
    By 02NavyBlue in forum Brakes/Suspension/Chassis
    Last Post: 05-11-2013, 07:44 PM
  4. There's trans fluid everywhere!!
    By FuglyGTP in forum General Tech Discussion
    Last Post: 09-05-2009, 05:08 PM
  5. Trans. Fluid?
    By BwolfGT in forum General Tech Discussion
    Last Post: 04-11-2009, 05:26 PM
