Thread: P0752 - Shift Solenoid A Stuck On
Results 1 to 15 of 15
  1. #1 P0752 - Shift Solenoid A Stuck On
    Banned
    Oct 2013
    Moorhead, MN
    Changed fluid. Old transmission fluid was fine. Replaced with 8 quarts of synthetic. Fluid level is good.
    What do?
    P0752
  2. #2 Re: P0752 - Shift Solenoid A Stuck On
  3. #3 Re: P0752 - Shift Solenoid A Stuck On
    Banned
    Oct 2013
    Moorhead, MN
    *shudder*
    Engine, cradle, and trans dropping is way beyond me. Nor do I have the tools.
  4. #4 Re: P0752 - Shift Solenoid A Stuck On
    There's little for special tools. If you look at my threads, you'll see most of the time I'm using simple things.
    4x4
    Jack
    Common tools
  5. #5 Re: P0752 - Shift Solenoid A Stuck On
    Banned
    Oct 2013
    Moorhead, MN
    I've read that replacing the part doesn't always fix it so that's why I ask here.
    Would a shift kit do anything? Anything I can do with my Torque App?
  6. #6 Re: P0752 - Shift Solenoid A Stuck On
    Dec 2012
    Where 4T65E's were born
    It's most likely the shift solenoid. It's not too common but not uncommon either. I didn't use a 4x4 in lowering the trans, just 2 jacks with a long 2x4 across both pans. 2x6 will work better. It's not hard, requires pretty average tools. I did it with the tools I had already, with the exception of having to buy a 36 mm socket.
    Sold.
  7. #7 Re: P0752 - Shift Solenoid A Stuck On
    Banned
    Oct 2013
    Moorhead, MN
    I just dumped a bottle of Lucas Trans Fix in it. I'm sure that will cure everything. Even the body rust.
    PS. Damn that stuff is thick!
  8. #8 Re: P0752 - Shift Solenoid A Stuck On
    Dec 2012
    I believe that's all it does for slipping transmissions. Transmissions slip due to loss of pressure usually, or worn clutches (usually worn that badly because of slipping) So thicker fluid flows slower, increasing pressure.
    Sold.
  9. #9 Re: P0752 - Shift Solenoid A Stuck On
    Trans fluid being too slow would make shift times super long. I'm not sold that's what Lucas does.
  10. #10 Re: P0752 - Shift Solenoid A Stuck On
    Banned
    Oct 2013
    Moorhead, MN
    From what I gathered, it also softens old seals and helps clean/lubricate valves.
    A $12 shot at a $2,000 problem! =D
  11. #11 Re: P0752 - Shift Solenoid A Stuck On
    Dec 2012
    A shift solenoid isn't $2000 lol. And I suppose there's other things that go into it like detergents. I didn't mean slow like 80w90, just slower so that it doesn't flow as fast through small openings cracks or worn surfaces. They could have made it the same viscosity as trans fluid with the same detergents if they wanted to.
    Sold.
  12. #12 Re: P0752 - Shift Solenoid A Stuck On
    Banned
    Oct 2013
    Moorhead, MN
    A rebuild is. =)
  13. #13 Re: P0752 - Shift Solenoid A Stuck On
    A trans swap isn't.
  14. #14 Re: P0752 - Shift Solenoid A Stuck On
    Banned
    Oct 2013
    Moorhead, MN
    Cheapest I found on that was Trans +600. And he wouldn't warranty the work.
  15. #15 Re: P0752 - Shift Solenoid A Stuck On
    Gille has a couple for $500 each
    and you appear to live in the middle of nothing 3800
  1. P0742 - Torque Converter Clutch Solenoid Circuit Stuck On
    By ls1camino in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-03-2017, 08:38 PM
  2. Replies: 1
    Last Post: 12-08-2012, 07:39 PM
  3. need help with shift solenoid
    By Amanda Garrett in forum General Grand Prix Discussion
    Last Post: 06-15-2012, 05:55 AM
  4. shift solenoid A
    By Thuglife2334 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-17-2012, 12:09 PM
  5. Shift solenoid
    By Junixx in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-06-2009, 05:22 PM
