On the way to work today, everything seemed normal, although it is like 30* outside this morning. I went and picked up the Hayden 404 and a new filter
I'll probably grab the fluid from wal-mart when i get off. I dont plan to flush it, but now that i seen how bad off the fluid looks, i feel i should at least get
something to replace and throw in a container of lucas. Im trying to find the shift kit pieces i let them loose in my tool bag, so im attempting to empty it
and retrieve them.
With the cooler, i'll probably try and run it separate from the internal cooler in the radiator. Anything to look out for? and when i clip the rubber portion
of the trans lines what size fitting would fit in there as i know the lines coming off the cooler are 3/8
