Thread: Dark trans fluid
Results 1 to 11 of 11
Threaded View
  1. #2 Re: Dark trans fluid
    Dec 2012
    Where 4T65E's were born
    Well I'm going to guess that you have quite a few miles on that, at least in the 160-180k range?
    P0742 is the torque converter clutch stuck on code. That's usually the fault of a $17 solenoid (TCC solenoid), and is accessible from the side cover. Which of course requires dropping one side of the subframe, not hard but requires a good amount of tools and time. That will probably have to get fixed, it's not going to get better.
    P1811 is usually the fault of another solenoid, the PCS. This can be covered up with a shift kit, but seeing as the TCC solenoid needs replacing, you'll probably just do them both, if at all.
    And loosing overdrive is the result of the 4th clutch hub failing. That takes a little more work to get into the trans, but as an average DIY'er like myself, I just replaced those 3 things in my trans not too long ago on my own.
    Also those temps are not abnormal, have you checked the coolant level? What was the ambient temp outside at the time?
    So at this point a shift kit and fluid filter with lucas trans stop slip may help only with P1811, but seeing as the fluid is dark that makes it iffy. How dark are we talking? And do NOT flush it, that's probably a 90% chance of killing it, especially at this point.
    Do you have tools to do things like dropping a subframe a foot? It takes 2 jacks and jack stands, 33 or 36 mm socket, socket set from 13-19mm, torx bits up to T40 etc. Overall it depends on if it's worth it to you to put the time and money into it, and of course the risks of it failing from something else soon.
    Sold.
  1. Dark Green Power Steering Fluid
    By scross in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-10-2013, 12:36 PM
  2. Trans fluid help!
    By CyxRyan in forum General Grand Prix Discussion
    Last Post: 08-29-2013, 12:17 PM
  3. Just flushed brake fluid, and now dark again
    By 02NavyBlue in forum Brakes/Suspension/Chassis
    Last Post: 05-11-2013, 07:44 PM
  4. There's trans fluid everywhere!!
    By FuglyGTP in forum General Tech Discussion
    Last Post: 09-05-2009, 05:08 PM
  5. Trans. Fluid?
    By BwolfGT in forum General Tech Discussion
    Last Post: 04-11-2009, 05:26 PM
