Thread: Pressure Control Solenoid(EPC), TCC, 4th Clutch Hub Replacement in the Vehicle.
Results 1 to 20 of 105
  1. #1 Re: Pressure Control Solenoid Replacement
    GT Level Member DJNight2k's Avatar
    Lorain, OH
    There are 2 bolt holes on the side cover with smaller holes (alignment holes) one on the lower left and one on the lower right. Tighten those first starting w the one on the right (rear of cover).
    Good diagram twizted 1.
    If i was going to take the channel plate off to do the 4th hub i would take off the valve body and do the boost valve while it was out and on a flat surface. Less chance of having to chase the check balls around. You would need new spacer plate gaskets or a new spacer plate with bonded gaskets on it (that's how they come from gm now). I probably have one of those too if you are interested. But that being said probably not totally necessary to change the boost valve if you don't want to deal with that.
  2. #2 Re: Pressure Control Solenoid Replacement
    Dec 2012
    Where 4T65E's were born
    I'm not sure how the diagram is telling me what bolts remove the VB as a complete assembly. Which bolts do and don't come out for that?
    Quote Originally Posted by DJNight2k View Post
    Yeah I don't really want to do the boost valve, it's not completely necessary and would cost me a bit more in gaskets.
    Sold.
  1. pressure control solenoid ?s
    By circa09 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-11-2011, 03:53 PM
  2. Pressure control solenoid?? HELP
    By gtpman in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-14-2010, 08:56 AM
  3. Trans pressure control solenoid replacement
    By PrixGT in forum General Tech Discussion
    Last Post: 07-06-2010, 09:21 AM
  4. Pressure Control Solenoid?
    By Klutch in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-04-2009, 01:09 AM
