Thread: Pressure control solenoid?? HELP
Results 1 to 3 of 3
  1. #1 Pressure control solenoid?? HELP
    Indianapolis
    car sits and sounds like the power steering pump or s/c is whining but its coming from the tranny and when it throws the code P1811 it acts like it doesnt know what gear to be in.i use my aeroforce scan gauge and clear the code the noise will go away and its all good. can anyone help.
  2. #2 Re: Pressure control solenoid?? HELP
    alabama
    does anyone have an internal diagram of the transmission where the solenoid is i need one real bad. any advice would be soooooooooooooooo appreciated because i am a single mother with 2 teenage children and no way to work because of this problem. I need a diagram really really bad! Thanks so much and god bless you all!
  3. #3 Re: Pressure control solenoid?? HELP
    Once you lower the trans out of the car enough to pull the side pan off, it's the 2nd soleniod down on the left. Or...the largest soleniod in the trans.
  1. Boost Control Solenoid/EVAP?
    By pski920 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-17-2012, 12:56 PM
  2. Pressure Control Solenoid?
    By Klutch in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-04-2009, 01:09 AM
  3. Pressure control solenoid, anyone got a writeup on changing it?
    By Merlin in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-29-2009, 11:05 PM
  4. Check Tire Pressure light on with no low pressure.
    By DanGTP in forum General Tech Discussion
    Last Post: 11-13-2008, 08:43 AM
