Thread: Developing hard-shifts / Towing / Need Opinions
Results 1 to 20 of 63
  1. #1 Re: Developing hard-shifts / Towing / Need Opinions
    GT Level Member 02GPinNY's Avatar
    Aug 2012
    Port Chester, NY
    I'm curious now after reading this thread. September 13th I'll be trailering my bike down to the races 120 miles away on pretty flat roads all the way. My bike weighs 480lbs. and the trailer (Harbor Freight) weighs 180lbs. I'm looking at less than 700lbs. total. The GP runs fine and has 140K on the clock. I'm having the pan dropped and filter changed this Friday. I'm hoping it will be okay to tow such a light weight. My thinking, which I'm not sure if it's correct is that if I had four adults, all my size in the car it would be 1,000lbs. I'd be towing 300lbs less weight. Just curious about your thoughts on this? Thanks.
    2002 GT Red, Stock, Work In Progress..........
  2. #2 Re: Developing hard-shifts / Towing / Need Opinions
    Quote Originally Posted by 02GPinNY View Post
    im sure you'd make it there and back. towing is easier on the car vs hauling the weight. but a cooler seems to worth it for any of us really.
  3. #3 Re: Developing hard-shifts / Towing / Need Opinions
    Aug 2012
    Port Chester, NY
    Thanks again Scotty. As soon as I get back from the races I have another week vacation. I'll install the cooler myself at that time. It's all 95 from my house to Exit 4 and then 55 South to Millville. Shouldn't be that hard on the tranny. I'm just gonna keep it in 3rd gear and take it nice and easy.
  4. #4 Re: Developing hard-shifts / Towing / Need Opinions
    GTP Level Member
    Aug 2012
    st louis park, MN
    You will make it there and back fine assuming everything is in good working order. Do you have a Heads Up Display (HUD) with a transmission temp readout? Also, I've heard that some older grand prix models do not have a "hardened 4th gear" or something to that effect. If you have the hardened 4th, then I don't think you'd have to keep it in 3rd gear unless the car starts shifting between the two gears frequently.
    I would disagree that towing is easier on a car than hauling weight. If I were hauling 1000lbs in my trunk, the shape and aerodynamics of my car don't change. If I am towing 1000lbs in the form of an open trailer with 2 motorcycles on it, a couple tires and gas cans, I've negatively changed the aerodynamics of my car and will therefore increase the constant load on my transmission. This is more and more true as speed increases - such as highway travel.
    I would argue that if I were to put this 1000lbs into my trunk I could still achieve close to or above 30mpg. While trailering with the setup mentioned above, I actually see about 21mpgs.
  5. #5 Re: Developing hard-shifts / Towing / Need Opinions
    Aug 2012
    Port Chester, NY
    Quote Originally Posted by stocker View Post
    On my 2002 I do have the HUD Display but not Tranny Temp. At least I don't see a tranny temp. Not sure if I have the "hardened" 4th or not. Is there a way to tell? Maybe start out in 4th and if she starts shifting up and down I'll know and switch to 3rd manually??
  1. Hard shifts..
    By Senshi09 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-22-2012, 03:29 AM
  2. 97 gtp trand shifting hard from 2nd to 3rd gear.update!!!! shifts hard in every gear?
    By Doug 97 gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-12-2012, 12:18 PM
  3. Hard shifts
    By zildjian102 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-10-2011, 10:41 AM
  4. Hard shifts
    By dbextreme in forum General Tech Discussion
    Last Post: 02-13-2010, 09:09 PM
  5. Hard Shifts.
    By Brammer in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-11-2009, 09:18 PM
